  3. How to constrain a large number of clocks and child clocks...
  • Subscribers 92
  • Views 7811
How to constrain a large number of clocks and child clocks as asynchronous to each other?
FormerMember
FormerMember over 3 years ago
Dear community
Our design has three main clocks. Let's call them clk1, clk2, and clk3. Each clock has several child clocks running at the same frequency. So the SDC file could look like this:
create_clock -name "clk1" -period 62.5 -waveform {0.0 31.25} [get_ports clk1]
create_clock -name "clk2" -period 250.0 -waveform {0.0 125.0} [get_ports clk2]
create_clock -name "clk3" -period 83.3 -waveform {0.0 41.65} [get_ports clk3]
create_generated_clock -name "clk1a" -divide_by 1 -source [get_ports clk1]   [get_pins clk1a]
create_generated_clock -name "clk1b" -divide_by 1 -source [get_ports clk1]   [get_pins clk1b]
create_generated_clock -name "clk1c" -divide_by 1 -source [get_ports clk1]   [get_pins clk1c]
create_generated_clock -name "clk2a" -divide_by 1 -source [get_ports clk2]   [get_pins clk2a]
create_generated_clock -name "clk2b" -divide_by 1 -source [get_ports clk2]   [get_pins clk2b]
create_generated_clock -name "clk2c" -divide_by 1 -source [get_ports clk2]   [get_pins clk2c]
create_generated_clock -name "clk3a" -divide_by 1 -source [get_ports clk3]   [get_pins clk3a]
create_generated_clock -name "clk3b" -divide_by 1 -source [get_ports clk3]   [get_pins clk3b]
create_generated_clock -name "clk3c" -divide_by 1 -source [get_ports clk3]   [get_pins clk3c]
The child clocks are, logically, synchronous to their parent clock and thus to other child clocks derived from the same parent clock, but asynchronous to child clocks from other parent clocks. So for example, clk1 and its childs clk1a, clk1b, clk1c, ... are asynchronous to clk2 and clk3 including their children. Vice versa, clk2 and clk3 are asynchronous to clk1 and its children. Same is true between clk2 and clk3.
How can I constrain this without having to write down every single combination?
  • RamesNaikBhukya
    RamesNaikBhukya over 3 years ago +1
    Hi, To constrain the timing of the clocks and their child clocks, you can use the "set_clock_groups" command in the SDC file. This command allows you to group clocks together and specify the relationship…
  • RamesNaikBhukya
    To constrain the timing of the clocks and their child clocks, you can use the "set_clock_groups" command in the SDC file. This command allows you to group clocks together and specify the relationship between them. In your case, you can group each parent clock and its child clocks together and specify that they are synchronous to each other.
    For example, to group clk1 and its child clocks together, you can use the following command:
    set_clock_groups -group [get_clocks -include_generated_clocks clk1] -synchronous
    This command groups all clocks related to clk1 together, including its child clocks, and specifies that they are synchronous to all other clock groups. You can use similar commands to group clk2 and its child clocks together and clk3 and its child clocks together.
    Using the "set_clock_groups" command allows you to constrain the timing of your clocks without having to write down every single combination. The command automatically considers all possible combinations within a clock group and constrains them accordingly.
    set_clock_groups -name "clk1_group" -group [get_clocks -include_generated_clocks -of [get_ports clk1]] -synchronous
    set_clock_groups -name "clk2_group" -group [get_clocks -include_generated_clocks -of [get_ports clk2]] -synchronous
    set_clock_groups -name "clk3_group" -group [get_clocks -include_generated_clocks -of [get_ports clk3]] -synchronous
    set_clock_groups -name "all_clocks" -group {clk1_group clk2_group clk3_group} -asynchronous
    In this example, we create a clock group for each parent clock and its child clocks, and then add these clock groups to a virtual clock group named "all_clocks". This ensures that all clocks in the same group are asynchronous with each other.
    Ramesh
  • FormerMember
    FormerMember over 3 years ago in reply to RamesNaikBhukya
    Great answer! Thank you very much.
    Can you elaborate the difference between these two variants?
  • RamesNaikBhukya
    RamesNaikBhukya over 3 years ago in reply to FormerMember
    The first variant uses the command:
    In this variant, the "get_clocks" command is used to get all the clocks in the design that are related to the clock "clk1", including the generated clocks derived from "clk1".
    The second variant uses the command:
    set_clock_groups -group [get_clocks -include_generated_clocks -of [get_ports clk1]]
    In this variant, the "get_ports" command is used to get the port object for "clk1", and then the "get_clocks" command is used to get all the clocks related to this port, including the generated clocks.
    The main difference between the two variants is in how the clock list is generated. The first variant gets all the clocks related to "clk1", regardless of where they are located in the design hierarchy. The second variant gets all the clocks related to the port object for "clk1", which may include clocks from other parts of the design hierarchy if they are connected to the same port as "clk1".
  • FormerMember
    Fantastic explaination, thank you very much.
    I added the following lines to my SDC file (the numbers in front are the line number):
    59: set_clock_group -name "clk1_group" -group [get_clocks -include_generated_clocks -of [get_ports clk1]] -synchronous
    60: set_clock_group -name "clk2_group" -group [get_clocks -include_generated_clocks -of [get_ports clk2]] -synchronous
    61: set_clock_group -name "clk3_group" -group [get_clocks -include_generated_clocks -of [get_ports clk3]] -synchronous
    62: set_clock_group -name "all_clocks" -group {clk1_group clk2_group clk3_group} -asynchronous
    Unfortunately, when reading in the SDC file I get some errors (I am using Innovus 21.10):
    **ERROR: (IMPTCM-67):    Option <patterns> and -of_objects are mutually exclusive. Check if more than one options that are mutually exclusive were given or if an invalid option was given.
    **ERROR: (TCLCMD-1009):    Conflicting options asynchronous and exclusive (File [...], Line 59).
    **ERROR: (TCLCMD-1009):    Conflicting options asynchronous and exclusive (File [...], Line 60).
    **ERROR: (TCLCMD-1009):    Conflicting options asynchronous and exclusive (File [...], Line 61).
    **WARN: (TCLCMD-513):    The software could not find a matching object of the specified type for the pattern 'clk1_group' (File [...], Line 62).
    **WARN: (TCLCMD-513):    The software could not find a matching object of the specified type for the pattern 'clk2_group' (File [...], Line 62).
    **WARN: (TCLCMD-513):    The software could not find a matching object of the specified type for the pattern 'clk3_group' (File [...], Line 62).
    **ERROR: (TCLCMD-917):    Cannot find 'clocks' that match 'clk1_group clk2_group clk3_group' (File [...], Line 62).
    Did I do something wrong?
  • FormerMember
    FormerMember over 3 years ago in reply to FormerMember
    Update:
    Using
    set_clock_group -name "all_clocks" -group [list [get_clock_groups clk_group] [get_clock_groups sclk_a_group] [get_clock_groups sclk_raw_group]] -asynchronous
    also does not work. It yields a
    **ERROR: (TCLCMD-917):    Cannot find 'clocks' that match '' (File [...] Line 62).
    error message.
