  3. Innovus: Special Route doesn't connect PG rails to PG R...
  • Subscribers 94
  • Views 4309
Innovus: Special Route doesn't connect PG rails to PG Rings
Anas2023a95
Anas2023a95 over 3 years ago
Dear all,
When I use the sRoute command to connect the PG rails, sRoute dosn't connect the rails to the PG ring, instead it stops routing at the core boundary, as shown below:
Is there a way to fix this and make it starts and finishes at the PG rings? The VerifyConnectivity sees those rails as antenna violations.
The command I'm using:
sroute -nets {VDD VSS} -connect {padPin} -padPinTarget {ring} -padPinPortConnect {allPort allGeom}
Kind regards,
Anas
  • FormerMember
    FormerMember over 3 years ago +1
    I suppose that with "PG rails" you mean the horizontal stripes of your standard cell rows (the ones that show a DRC violation in your picture)? I'm asking because the command you provided will only connect…
  • FormerMember
    I suppose that with "PG rails" you mean the horizontal stripes of your standard cell rows (the ones that show a DRC violation in your picture)? I'm asking because the command you provided will only connect pad pins to your core ring. If my assumption is right, try using
    sroute -nets {VDD VSS} -connect {corePin} -corePinTarget {ring}
  • Anas2023a95
    Anas2023a95 over 3 years ago in reply to FormerMember
    Thanks, Domi!
    That is exactly what I meant and the solution worked perfectly.
