  3. Voltus: WARNING IMPEXT-2773
  • Subscribers 94
  • Views 7132
Hieu Hoang
Hieu Hoang over 3 years ago
Hi Cadence Supporter,
I'm a newbie with Voltus.
When I'm trying to run dynamic rail analysis, I got an warning IMPEXT-2773 with the following message:
The via resistance between layers M0 and M1 could not be determined from the LEF technology file because the via resistance specification is missing. A default of 4 Ohms will be used as via resistance between these layers.
How could I do for passing this warning?
thanh you so much
