  3. Verilog netlist to Schematics
  • Subscribers 95
  • Views 11048
Anas2023a95
Anas2023a95 over 3 years ago
Dear all,
I have an RTL design synthesized by Genus, and placed and routed by Innovus.
In the process of verifying the design, I was thinking of running Corner Analysis. I have done such analysis before using Virtuoso for a schematic view design.
So, I started thinking about how I could convert the netlist generated by Genus to a schematic that I could open in Virtuoso and run the different simulations.
I tried using the Verilog In tool in Virtuoso (File -> Import -> Verilog) but that didn't quite work.
Log output:
@(#)$CDS: ihdl version 6.1.8-64b 10/05/2021 19:14 (cpgsrv11) $ Wed Aug 30 15:49:50 2023
INFO (VERILOGIN-589): Using xmvlog binary for compilation.
ERROR (VERILOGIN-540): visadev load failed
INFO (VERILOGIN-206): End of Logfile.
Any suggestions? Many thanks.
Kind regards,
Anas
  • Andrew018
    Andrew018 over 3 years ago
    Consider exploring options for netlist conversion or simulation tool compatibility. You might find success with tools like Cadence's NC-Sim or Synopsys' VCS, which are better suited for RTL simulation and analysis, allowing for a smoother transition from Genus to Virtuoso. Also, check out AC Football Cases
