  3. innovus placement related issue
  • Subscribers 95
  • Views 9580
PacificFeng
PacificFeng over 3 years ago
Dear all,
I have two questions:
(1) I am wondering if innovus has the function of global placement, which is w/o legalization.
(2) Can I costumize the goal of legalization? Or its cost function is fixed?
I have found so long, and still having no idea.
Thank you very much!
  • DimoM
    DimoM over 3 years ago
    you can turn off legalization and run the global placer only with the following command:
    setPlaceMode -place_design_refine_place false
    place_design
    I am not aware of direct ways of modifying the cost function, at least not available to the public.
    What you can do is, for example, modify the weight of certain nets with specifyNetWeight.
    - Dimo
  • PacificFeng
    PacificFeng over 3 years ago in reply to DimoM
    Hi Dimo,
    Thank you very much! I will try this way!
    Best regards,
    PacificFeng
