  3. Change mode of oa_update_mode from false to true
  • Subscribers 95
  • Views 6843
Matilde
Matilde over 2 years ago
I am having a problem related to the setting of the oa_update_mode from false to true: when I run, after P&R, DRC and LVS, the power analysis I get this error:
Firstly, I tried to change the mode in my P&R script but I still get this error. I look for a solution everywhere and actually I did not get very well what does it mean "Free the design from memory" and I should do too.
By the way, I got power results and I do not figure out if this error really affect my results.
Can someone help me?
Thank you in advance
  • spojer
    spojer over 2 years ago +1
    Hello, The Warning message tells you to set the oa_update_mode before loading the design. You can't change this attribute once a design is loaded. Please have a look at detailed explanation when and why…
  • spojer
    Please have a look at detailed explanation when and why to change this attribute to true in Innovus Stylus Common UI Text Command Reference.
