  3. setExtractRCMode command not found with "innovus -stylus...
  • Subscribers 94
  • Views 4311
setExtractRCMode command not found with "innovus -stylus" option, but is available if "innovus" is run
bong95
bong95 over 2 years ago
Hello community,
I am very new to innovus and came across a very strange problem. The "setExtractRCMode" command is not found by Innovus if I start the Innovus with "-stylus" option. Did someone face any similar issue or have any info about any alternative command for the same?
  • turtlej9
    turtlej9 over 2 years ago in reply to bong95 +3
    get_common_ui_map setExtractRCMode will give you the new command (When moving from legacy to stylus, it's smart to write that command on a sticky note because you will use it A LOT to find the new commands…
  • bong95
    bong95 over 2 years ago +1
    Any help from anyone?
  • bong95
    bong95 over 2 years ago in reply to turtlej9 +1
    Thanks a lot turtlej9 !!
  • bong95
  • turtlej9
    get_common_ui_map setExtractRCMode  will give you the new command  (When moving from legacy to stylus, it's smart to write that command on a sticky note because you will use it A LOT to find the new commands)
    • Vote Up +3 Vote Down
  • bong95
    Thanks a lot turtlej9!!
