  3. Failed to synthesis RISCY core on genus legacy.
  • Subscribers 94
  • Views 9380
Amal K
Amal K over 2 years ago
Hi, after trying to synthesis the RISCY core in genus legacy tool, I'm getting the following error. It says the 'cv32e40p_apu_core_pkg' is missing. But I already included it along with the RTL. Also all the files are in system verilog.
Can anyone help me with this. We are trying to benchmark RISCY core by obtaining power, area and time etc.
Error : Reference to non-existent package. [VLOGPT-28] [read_hdl]
: Reference to non-existent package 'cv32e40p_apu_core_pkg' in file '/home/user1/amal/risc_Y/src/cv32e40p_core.sv' on line 31, column 49.
: The referenced package does not exist.
output logic [APU_NARGS_CPU-1:0][31:0] apu_operands_o,
This is the TCL script i used.
set DESIGN cv32e40p_core
set_attribute information_level 7
set_attribute init_lib_search_path {/home/install/FOUNDRY/digital/45nm/dig/lib/slow.lib}
set_attribute init_hdl_search_path {/home/user1/amal/risc_Y/src}
#read_libs
#set_attribute library $lib
set a {\
cv32e40p_core.sv \
cv32e40p_apu_core_pkg.sv \
cv32e40p_fpu_pkg.sv \
cv32e40p_pkg.sv \
cv32e40p_sleep_unit.sv \
cv32e40p_if_stage.sv \
cv32e40p_prefetch_buffer_i.sv \
cv32e40p_prefetch_controller.sv \
cv32e40p_fifo.sv \
cv32840p_obi_interface.sv \
cv32e40p_aligner.sv \
cv32e40p_compressed_decoder.sv \
cv32e40p_id_stage.sv \
cv32e40p_register_file_latch.sv \
cv32e40p_decoder.sv \
cv32e40p_controller.sv \
cv32840p_int_controller.sv \
cv32e40p_hwloop_regs.sv \
cv32e40p_ex_stage.sv \
cv32e40p_alu.sv \
cv32e40p_ff_one.sv \
cv32e40p_alu_div.sv \
cv32e40p_mult.sv \
cv32e40p_apu_disp.sv \
cv32e40p_load_store_unit.sv \
cv32e40p_obi_interface.sv \
cv32e40p_cs_registers.sv \
cv32e40p_pmp.sv \
cv32e40p_popcnt.sv \
cv32e40p_sim_clock_gate.sv
read_hdl -sv $a
elaborate $DESIGN
current_design cv32e40p_core
create_clock -period 5 -name CLK [get_ports {clk_i}]
set_input_delay -max 1.67 ["all_inputs"] -clock CLK
set_output_delay -max 1.67 ["all_outputs"] -clock CLK
set_clock_uncertainty 0.25 [get_clock CLK]
set_max_transition 0.25
set_max_capacitance 0.4 ["all_outputs"]
set_max_fanout 32 ["all_inputs"]
check_design
set_attribute syn_generic_effort medium
syn_generic
report summary
set_attribute syn_map_effort medium
syn_map
report summary
set_attribute syn_opt_effort medium
syn_opt
report summary
report_timing > /home/user1/amal/risc_Y/reports/timingcore.rpt
report_power > /home/user1/amal/risc_Y/reports/powercore.rpt
report_area > /home/user1/amal/risc_Y/reports/areacore.rpt
report_qor > /home/user1/amal/risc_Y/reports/qorcore.rpt
report_timing -num_paths 200000 > /home/user1/amal/risc_Y/reports/timing_num_pathccore.rpt
report_timing -from [all_inputs] -to [all_registers] > /home/user1/amal/risc_Y/reports/report_input2reg.txt
report_timing -from [all_registers] -to [all_registers] > /home/user1/amal/risc_Y/reports/report_reg2reg.txt
report_timing -from [all_registers] -to [all_outputs] > /home/user1/amal/risc_Y/reports/report_reg2output.txt
report_timing -from [all inputs] -to [all_outputs] > /home/user1/amal/risc_Y/reports/report_input2output.txt
write_hdl > /home/user1/amal/risc_Y/outputs/netlistcore.v
write_sdc > /home/user1/amal/risc_Y/outputs/sdccore.sdc
#write_db > /home/soorajm/Documents/genus/Outputs/sdcmkccore12nm.db
  • RolfA
    RolfA over 2 years ago +1
    I'm using the same core downloaded from github. In my installation the missing package is in a different directory (path) than the rest of the code. rtl/include/cv32e40p_apu_core_pkg.sv vs rtl/cv32e40p_core…
  • RolfA
     rtl/include/cv32e40p_apu_core_pkg.sv vs rtl/cv32e40p_core.sv
    check your init_hdl_search_path
    Best regards
    Rolf
  • Amal K
    Amal K over 2 years ago in reply to RolfA
    Hi RolfA.
    I included all the files including the pkg files in the same folder. Then included the path in hdl_search path. But did't work.
  • RolfA
    RolfA over 2 years ago in reply to Amal K
    Hi Amal
    Try to reorder the file list "a", so that the packages are first and the core is last in the list.
    You can look in the cv32e40p_manifest.flist for the proper order.
    Cheers
    Rolf
