  3. ERROR IMPCCOPT-4082 when running ccopt_design command in...
  • Subscribers 95
  • Views 10493
ERROR IMPCCOPT-4082 when running ccopt_design command in Innovus 22.1
bong95
bong95 over 2 years ago
Hi everyone,
I am trying to do the clock tree synthesis using Innovus 22.1 and it is facing the following error:
1. **ERROR: (IMPCCOPT-4082): No timing clocks found therefore cannot extract clock trees. An SDC file should be loaded.
2. **ERROR: (IMPCCOPT-2004): Cannot run 'update_clock_tree_spec_annotations -include_ideal_net_status' as no clock trees are defined.
Although, I have included the sdc file (which got generated by Genus) in the mmmc file before init_design step. I am using the Innovus common UI. Any suggestion how to bypass this error will be very helpful for me. Thanks in advance!
  • bong95
    bong95 over 2 years ago in reply to Ayma +1
    Hello, For me there was a problem in the SDC file generated by Genus. There was no "create_clock" command in the sdc file due to some script error. Maybe check your sdc file.
  • Ayma
    Ayma over 2 years ago in reply to bong95 +1
    Yeah it was something similar with the sdc generated from genus in my case too. Thanks a lot for your reply!!
  • Ayma
    Please let me know if you found a solution for this issue?
    Thank you.
  • bong95
  • Ayma
