  3. Genus netlist generation (write_hdl) takes very long ti...
  • Subscribers 94
  • Views 7086
Genus netlist generation (write_hdl) takes very long time
ACMTUG
ACMTUG over 2 years ago
I am trying to synthesize a relatively large design (consuming ~56mm^2) using Cadence genus211_21.15.
Design involves many gate-level operations and I'm using already generated netlists as submodules (by reading them using "read_netlist") to speedup the synthesis runtime.
I also use "preserve" and "ungroup" to further improve synthesis time. This indeed improves the synthesis time significantly.
However, netlist generation (write_hdl) takes very very long time.
For a smaller design, the same approaches finished the synthesis in ~30 minutes; however, netlist generation took 3 days! (The size of final netlist verilog file is only 600KB).
Did anyone face similar issue? I'll appreciate any suggestion to solve this issue.
Thanks.
