  3. Assistance with Followpin Connection to Power Ring
  • Subscribers 95
  • Views 5630
Anas2023a95
Anas2023a95 over 1 year ago
Dear All,
As shown in the image below, some followpins (in blue) fail to connect to the power ring. This appears to be because the horizontal tracks connecting the power pad on the right to the power ring extend to the outermost ring instead of terminating at the nearest one.
I believe the DRC violation can be resolved by instructing the tool to connect the power pads to the nearest rings (on the right side). This would allow the followpins to connect to the left-side rings.
I’m currently using the following command for routing:
route_special -connect {block_pin pad_pin pad_ring core_pin floating_stripe} -layer_change_range { M1(1) AP(8) } -block_pin_target {nearest_target} -pad_pin_port_connect {all_port one_geom} -pad_pin_target {nearest_target} -core_pin_target {first_after_row_end} -floating_stripe_target {block_ring pad_ring ring stripe ring_pin block_pin followpin} -allow_jogging 1 -crossover_via_layer_range { M1(1) AP(8) } -nets { VDD VSS } -allow_layer_change 1 -block_pin use_lef -target_via_layer_range { M1(1) AP(8) }
Could you please advise on what changes are needed to achieve this? I’ve experimented with various options but haven’t found a solution.
Many thanks,
Anas
  • DimoM
    DimoM over 1 year ago
    Hi Anas,
    it seems like your attachment upload failed. Can you try to attach the photo again ?
    - Dimo
  • DimoM
    I just saw the picture in the other thread.
    It seems that you are using wire groups for the rings.
    I would suggest to divide the problem into two separate routing tasks - connect pad to rings, then connect followpins to rings.
    You can use the route_special command switches to achieve that.
    Also you probably want to connect all shapes in the group to the pad ports.  This article might be relevant for your problem:
    How to use sroute to connect macro pins to the nearest ring or wire group stripes
    - Dimo
