  3. Innovus: IO Pin Placement After Routing
  • Subscribers 94
  • Views 5854
Anas2023a95
Anas2023a95 over 1 year ago
Dear all,
After routing the design, I noticed that all pins were moved to the origin ({0,0}). Running assign_io_pins successfully relocated most of them to the "PAD" port of their respective I/O pad instances, but some remain floating at the boundary.
The report summary indicates unplaced pins and floating IOs.
I attempted to manually move them using edit_pin, but it only allows movement along the boundary without placing them on the "PAD" port.
For example, the pin OTP_VCC should be placed on the AVDD pad of the OTP_VCC I/O pad instance. The corresponding net is VCC, so I tried:
connect_pin -inst OTP_VCC -pin AVDD -net VCC
assign_io_pins
However, this did not work.
Any suggestions would be greatly appreciated.
Thank you,
Anas
