  3. Innovus place and route
  • Subscribers 94
  • Views 5933
AB202504284945
AB202504284945 over 1 year ago
Hallo i am an Innovus 15.2 user, i would like to make a place and route of my design  inside a "L"- shaped polygon. My question is : is possible to make a "floorplan" die using a non - reptangular shape? By now i have been trying to avoid this problem by making different inst groups on several reptangules inside the floorplan shape by using the commands "createInstGroup",  "addInstToInstGroup", "createPlaceBlockage", but i cannot place the digital pins on their edges, since the tool only allows to place the pins on the edge of the main die, which is reptangular. The pins are going to be used to communicate with external analog entities, on the same chip. Is there a way to customize digital design placing and pin placing ?
Thank you in advence
