  3. Residual power in whole design vs summed gate groups in...
  • Subscribers 94
  • Views 3552
Residual power in whole design vs summed gate groups in Joules, even with full instance coverage
SR202412023415
SR202412023415 over 1 year ago
Hi everyone,
I'm running power analysis in Joules (Version v21.19) using simulation-based activity from a VCD file for a purely combinational design (ISCAS-85 c432). To understand the power contribution of different parts of the circuit, I split the gate-level netlist into two groups: odd and even gates, Based on their gate IDs (i.e., simply splitting them). Every single cell instance in the netlist is assigned to exactly one of these two groups; there is no gate left unaccounted for.
I then use Joules to compute:
  • Power of the entire design
  • Power of just the odd gate group
  • Power of just the even gate group
At key simulation times (e.g., 21 ns, when input vectors change), I observe a significant difference between:
Total power reported by Joules vs. Sum of power of `odd` and `even` gate groups
For example, at 21 ns:
  • Whole design power = 0.000438382069755 W
  • Odd group power = 0.000196574924795 W
  • Even group power = 0.000208780383976 W
  • Residual = ~33 µW
Despite confirming that:
  • All cell instances in the design are included across both groups
  • There are no flops, clock trees, or unlisted primitives
  • The switching activity is fully captured from gate-level simulation
  • There is no sequential logic or memory macro in this design
I still observe this non-zero residual power.
My questions:
1) Where is the extra power coming from in the "whole" design that is not reflected in the sum of gate groups?
2) Is Joules attributing interconnect (net-level) switching power or glitching activity separately from gate instance power?
I also observed these results even in other designs.
I appreciate your help in advance.
Best regards,
Saeid
You can find the commands that I am calculating the power:
read_stimulus -file [getenv VCD] -dut_instance /c432_tb/dut -frame_count [getenv FRAME_COUNT]
power_map
compute_power
set vcd_filename [file tail [getenv VCD]]
set trace_basename [file rootname $vcd_filename]
# Generate the power report and PNG with unique filenames
report_power -out "${trace_basename}.data"
compute_power -mode time_based
plot_power_profile -format png -unit W -out "${trace_basename}.png"
