  3. ecoChangeCell
  • Subscribers 97
  • Views 4677
ecoChangeCell
MA202509235119
MA202509235119 over 1 year ago
Hi, I’m new to using Innovus and I’m trying to rename a submodule called “abc” to a new submodule "abc2" with the same ports in a netlist. The structure looks like this: top/u_abc. I need to change the module name of “u_abc” from “abc” to “abc2”. I’m trying to use ecoChangeCell with “top” set as the top_cell, but I can’t proceed because “top/u_abc” isn’t identified as an instance (it’s in hinsts). Can anyone help me with this?
  • KL202411246729
    KL202411246729 11 months ago
    changing in verilog is more faster right?
  • JD20251204503
    JD20251204503 11 months ago in reply to KL202411246729
    If you want change only hinst name use "changeInstName" is more easy
    please refer to https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nVAWEA2&pageName=ArticleContent (Cadence support)
