  3. "Undefined scan chain" error during Innovus `place`
  • Subscribers 95
  • Views 6347
GS202507021424
GS202507021424 over 1 year ago
I'm trying to run a RocketChip (rv64gc) design through the Genus/Innovus synth+place&route flow (with gpdk045 as the underlying technology), and running into a "scan chain" related issue during Innovus place (and subsequently cts). During place, I get this error:
    [check_scan_connected]: number of scan connected with
        missing definition = 5267, number of scan = 18274,
        number of sequential = 27937, percentage of missing
        scan cell = 18.85% (5267 / 27937)
    **ERROR: (IMPSP-9099): Scan chains exist in this design
        but are not defined for 18.85% flops. Placement and
        timing QoR can be severely impacted in this case!
    It is highly recommend to define scan chains either through
        input scan def (preferred) or specifyScanChain.
If I ignore this and continue by running cts, I then get this error:
    **ERROR: (IMPCCOPT-1349): Clock tree clock connects to 5 module(s)
        without definitions in the netlist.
    **ERROR: (IMPCCOPT-2196): Cannot run ccopt_design because
        the command prerequisites were not met. Review the previous
        error messages for more details about the failure.
Synthesis (with Genus) completes error-free, for whatever that's worth...
I suspect that this is somehow related to the RocketChip's debug interface, which has its own independent debug_clock and a few additional *reset signals:
    module ExampleRocketSystem(
      input         clock,
      input         reset,
      input         resetctrl_hartIsInReset_0,
      // debug interface:
      input         debug_clock,
      input         debug_reset,
      output        debug_clockeddmi_dmi_req_ready,
      input         debug_clockeddmi_dmi_req_valid,
      input  [6:0]  debug_clockeddmi_dmi_req_bits_addr,
      input  [31:0] debug_clockeddmi_dmi_req_bits_data,
      input  [1:0]  debug_clockeddmi_dmi_req_bits_op,
      input         debug_clockeddmi_dmi_resp_ready,
      output        debug_clockeddmi_dmi_resp_valid,
      output [31:0] debug_clockeddmi_dmi_resp_bits_data,
      output [1:0]  debug_clockeddmi_dmi_resp_bits_resp,
      input         debug_clockeddmi_dmiClock,
      input         debug_clockeddmi_dmiReset,
      output        debug_ndreset,
      output        debug_dmactive,
      input         debug_dmactiveAck,
      // mem_axi4_0 64-bit data width AXI (master) port;
      // mmio_axi4_0 64-bit data width AXI (master) port;
      // l2_frontend_bus_axi4_0_axi4_0 64-bit data width AXI (slave) port;
      input  [7:0]  interrupts
    endmodule
In the .sdc file for Genus (synthesis), I have designated clock as the clock signal (using create clock -name "clock" -period ...), but I'm unsure of whether (and how) to deal with the debug_clock signal, or if that's even the way to address the subsequent "scan chain" errors I get during place...
Any clues, tips, or pointers much appreciated!
  • Pascal
    Pascal over 1 year ago +1
    Try putting thic command "set_db / .use_scan_seqs_for_non_dft" false in genus after elaboration and befor syn_gen
  • GS202507021424
    I've also tried this with a very simple (8bit GCD) example with giolib045 pads -- absolutely no *deliberate* scan chains in that design!
    During `place`, I get IMPSP-9099.
    I tried working around it based on this older post:  ERROR: (IMPSP-9099): Scan chains exist in this design but are not defined for xx% flops
    Using ` setPlaceMode -place_design_floorplan_mode true` (in pre_place.tcs) fails with IMPSP-9537 -- says I should "use place_design" instead, not sure how I'd force it to do that...
    Using `setPlaceMode -place_global_ignore_scan false` does *not* get rid of IMPSP-9099.
    Ignoring these errors (by exiting from the tcl prompt I'm thrown into) then subsequently causes me to run into `cts` errors: (IMPCCOPT-2028): Too many clock instances are unplaced in the clock tree for CCOpt to continue.
    Is there a standard way to prevent Innovus from wrongly assuming the existance of scan chains?
    Thanks!
  • Pascal
  • GS202507021424
    GS202507021424 over 1 year ago in reply to Pascal
    Hi Pascal,
    Many thanks, that did it!!!
    I guess I need to remember GENUS*/doc/genus_attref/genus_attref.pdf for future reference, as a place to look for in cases where I feel "there ought to be a flag that does this" :)
  • Pascal
    Pascal over 1 year ago in reply to GS202507021424
    i am happy to help!
