  3. Procedure in Innovus common UI to generate scripts for ...
  • Subscribers 94
  • Views 4654
Procedure in Innovus common UI to generate scripts for placement
nrk1
nrk1 over 1 year ago
In an older Innovus version (152), the following lines were executed before placement. pnrflow/ was generated in innovus using "writeFlowTemplate -directory pnrflow"
  • ./pnrflow/SCRIPTS/gen_flow.tcl all
  • make init
In the new common UI, "writeFlowTemplate" is replaced by "write_flow_template" according to the manual (foundation flows guide). When I run "write_flow_template -directory scripts" it generates the folder scripts/ and scripts/flow with the following content. How do I proceed? Web search points to a script "scripts/run_flow.tcl" as the equivalent of gen_flow.tcl, but no such script is generated in my case. Basically I need to equivalent of "gen_flow.tcl" and "make init" mentioned above.
scripts> 291: ls
design_config.template eco_config.template flow.yaml_template innovus_config.template setup.yaml_template
dist.py* flow/ flow_config.template metric_config.yaml
scripts> 292: ls flow
common_flows.tcl common_steps.tcl innovus_steps.tcl
Innovus version info:
Version: v21.18-s099_1, built Tue Jul 18 13:03:50 PDT 2023
Options: -stylus
Nagendra
  • NK202510274558
    NK202510274558 over 1 year ago
    (I posted this on "Digital Implementation" forum a couple of weeks ago. I noticed that only a couple of posts in the last six months on that forum have replies. Hence trying my luck here.)
    • make init
    scripts> 291: ls
    Options: -stylus
    Nagendra
