  3. Xcelium 24.03+: how to get a single $setuphold line in annotation...
  • Subscribers 94
  • Views 150
Xcelium 24.03+: how to get a single $setuphold line in annotation summary (without separate $setup/$hold rows)?
TU202610195844
TU202610195844 27 days ago
After upgrading from Xcelium 24.03 to a release at or after 24.09, I see a change in the SDF annotation statistics. The option -sdf_splitvlog_setuphold appears to be the default now and when I use it in newest versions, I see a warning that this option is deprecated. As far as I can tell, there is no documented option to get the old behavior back.
What I see
My design uses only combined $setuphold timing checks in the specify block, and the SDF has combined SETUPHOLD entries as well. With -scopewise_sdfstats_log, the statistics table now also lists $setup and $hold as separate rows below $setuphold. In 24.03 only the combined $setuphold row was shown.
Minimal reproducer
design.sv:
module dut (input clk, input d, output reg q);
  always @(posedge clk) q <= d;
  specify
    (clk *> q) = (1.0, 1.0);
    $setuphold(posedge clk, d, 0.1, 0.1);
  endspecify
endmodule
test.sdf:
(DELAYFILE
  (SDFVERSION "2.1")
  (DESIGN "dut")
  (DATE "2026-10-14")
  (VENDOR "Example")
  (PROGRAM "Custom")
  (VERSION "1.0")
  (DIVIDER /)
  (VOLTAGE 1.0)
  (PROCESS "typ")
  (TEMPERATURE 25.0)
  (CELL
    (CELLTYPE "dut")
    (INSTANCE)
    (DELAY
      (ABSOLUTE
        (IOPATH clk q (1.0:1.0:1.0) (1.0:1.0:1.0))
    (TIMINGCHECK
      (SETUPHOLD d (posedge clk)
        (0.1:0.1:0.1)
        (0.1:0.1:0.1)
sdf.cmd:
SDF_FILE          = "test.sdf",
SCOPE             = tb.u_dut,
LOG_FILE          = "sdf_annotation.log",
MTM_CONTROL       = "TYPICAL";
testbench.sv:
module tb;
  reg clk = 0;
  reg d = 0;
  wire q;
  dut u_dut (.clk(clk), .d(d), .q(q));
  initial begin
    #10 clk = 1; #10 clk = 0;
    #10 d = 1;
    #50 $finish;
  end
endmodule
Compile options: -timescale 1ns/1ps -sysv -sdf_cmd_file sdf.cmd -scopewise_sdfstats_log /dev/stdout
Resulting output (relevant part)
Path Delays   1   0   1   100.00
$setuphold    1   0.00   1.00   100.00
      $setup  1   0   1   100.00
       $hold  1   0   1   100.00
The summary lines still say No. of Tchecks = 1, and annotation is 100%. So I assume this is only a change in the report format and not in simulation behavior. Please correct me if that is wrong.
Question
Is there a documented (or undocumented) option or setting in the current releases that restores the old reporting/behavior, with combined $setuphold line and no $setup/$hold breakdown (even when I use combined $setuphold both in the .sdf and in the RTL files)?
