  3. How does Innovus calculate transition mean and sigma with...
  • Subscribers 94
  • Views 133
How does Innovus calculate transition mean and sigma with CCS + LVF, given that Liberty defines nominal transition using NLDM tables?
YW202511205917
YW202511205917 8 days ago
Background
I am using Innovus 23.32-s091_1 for post-route timing analysis with detailed parasitics and SI.
The standard-cell libraries contain both:
  • CCS driver and receiver models
  • rise_transition / fall_transition
  • Early/late ocv_sigma_*_transition
  • Moments-based ocv_mean_shift_*_transition, ocv_std_dev_*_transition, and ocv_skewness_*_transition
The library corner is SS, 0.675 V, 125 °C. The Model types section of reportDelayCalculation identifies both the relevant driver and receiver as CCS.
What is confusing me
The Liberty 2017.06 manual explicitly defines:
  1. PDF page 696, printed page 15-14:
    • The nominal value corresponding to ocv_sigma_rise_transition is specified by rise_transition.
    • The nominal value corresponding to ocv_sigma_fall_transition is specified by fall_transition.
  2. PDF pages 710-713, printed pages 15-28-15-31:
    • The moments-based LVF syntax also identifies rise_transition / fall_transition as the nominal transition tables.
    • It defines:
Code block
mean rise transition = nominal rise transition
                       + ocv_mean_shift_rise_transition
with the equivalent relationship for falling transitions.
However, with CCS and detailed RC, the tool also computes voltage waveforms at the driver output and receiver inputs.
I understand that CCS and LVF can be used together. My question is specifically how the LVF statistics, referenced to the nominal transition tables, are applied to the CCS-based waveform calculation.
Questions
  1. What nominal transition does Innovus use when applying LVF in CCS mode?
    • The value obtained from rise_transition / fall_transition?
    • A transition measured from a CCS-generated waveform?
    • Or a transformed/calibrated combination of these?
  2. Are the following expressions valid, and under what assumptions?
Code block
Reported transition mean
    = slew measured from a CCS waveform + LVF mean_shift
Reported transition sigma
    = the interpolated LVF sigma/std_dev table value
I have not found documentation establishing these expressions. In particular, the first expression appears to replace the nominal reference explicitly defined by Liberty.
  1. If the CCS waveform-based slew differs from the nominal transition table value, how does Innovus map the LVF mean shift and standard deviation to the actual RC-loaded stage?
    Are they applied as absolute offsets, normalized/scaled, or processed through another statistical model?
  2. What is the statistical meaning of the waveforms reported by reportDelayCalculation -waveform in a SOCV/LVF analysis?
    Are they nominal waveforms, mean-adjusted waveforms, or something else? Can their threshold-crossing times be compared directly with the reported transition mean?
  3. Which reports or settings can expose this calculation?
    I would like to identify the actual LVF tables and lookup coordinates used, the nominal reference, and any statistical propagation or waveform-related adjustments.
Example report
For the net arc:
Code block
INV_X3/ZN → detailed RC network → DFHCQHSXG_X4/D
reportDelayCalculation -max -si reports:
Code block
Transitions                  Rise          Fall
Input transition  (mean):    0.052500 ns   0.057700 ns
                  (sigma):   0.001845 ns   0.001767 ns
Output transition (mean):    0.135100 ns   0.134100 ns
This is a net arc: "Input transition" refers to the driver output pin, and "Output transition" refers to the receiver input pin—not the cell's input-to-output arc.
Could someone point me to the relevant Cadence documentation or explain the calculation? I am trying to reconcile the Liberty-defined nominal reference with the transition mean and sigma actually reported by Innovus, rather than merely confirm that CCS and LVF can coexist.
