  2. Functional Verification
  3. Is there a way to disable specific timing checks
  • Subscribers 67
  • Views 20362
MaurizioCDN
MaurizioCDN over 17 years ago
we are doing a gate-level simulation with back-annotated SDF file. We have some timing violations on resynchronization FF.s between 2 different clock domains. Violations causes X to propagate all ovewr the circuit causing simulation to fail. In reality X will not propagate since double-synchronization ensure that possible meta-stability will resolve.
Is it possible to instruct simulation tool to disable notifier/timing checks for a specific instance ( w/o haciking SDF file)?
Maurizio Spadari
  • asedehi99
    asedehi99 over 17 years ago
    Anyone have an update on this?
  • Alex75
    Alex75 over 17 years ago
     use the following switch during elaboration:
    -tfile <my_tfile_name>
    this timing file holds the path to the first sync register and disables all the timing behaviour and all checks. your can also disable timing only (see cadence documentation). One example line looks like this:
    PATH    :top.module1.module2.module3.first_sync_reg    -timing
     happy netlist debugging :-)
    Alex
