  2. Functional Verification
  3. Problem with functional coverage
  • Replies 9
  • Subscribers 68
  • Views 20258
danlarkin
danlarkin over 18 years ago
I'm having a problem with functional coverage collection. When I run the following testcase and inspect the results using ICCR I'm getting zero functional coverage. The relevant coverage directories are being created and I'm seeing the cover group inside ICCR so I'm not sure what I'm doing wrong?
Any thoughts?
module test();
class gen;
  rand logic[7:0]    a;
  rand logic[7:0]    b;
  event              ev_collect_coverage;
  covergroup cg_all @ev_collect_coverage;
    c_a:             coverpoint a;
    c_b:               coverpoint b;
    cx:                cross c_a,c_b;
  endgroup
  function new( );
    cg_all = new;
  endfunction: new
  function void post_randomize();
    ->ev_collect_coverage;
  endfunction : post_randomize
endclass
gen testgen;
bit flag;
initial
begin
  testgen = new();
  for (int i=0; i<10; i++)
    begin
      $display("------------------------------------------------------------");
      $display("---- CONFIG = %d",i);
      flag = testgen.randomize();
      $display("A=%b",testgen.a);
      $display("B=%b",testgen.b);
    end
end
endmodule
  • tpylant
    tpylant over 18 years ago
    You are having an issue because there is no time elapsing between your events. You can work around this by adding a delay or using the sample( ) method instead of using an event to trigger the coverage collection.
    class gen;
      rand logic[7:0]    a;
      rand logic[7:0]    b;
        c_a:             coverpoint a;
        c_b:               coverpoint b;
        cx:                cross c_a,c_b;
      endgroup
      function new( );
        cg_all = new;
      endfunction: new
        cg_all.sample();
    endclass
    Tim
  • danlarkin
     Thanks! thats solved the issue.
  • danlarkin
    Just a brief follow-up question, is quering the coverage database through the coverage constructs (SystemVerilog LRM 18.7) supported? Because when I try to I get the following error message:
    This is not a valid built in method name for this object. [SystemVerilog].
    I've added the following inside the initial block of the above simple (corrected) testcase:
    cov_pt = testgen.cg_all.c_a.get_coverage();
    $display("CoverPoint coverage is %f", cov_pt);
    I also seem to get an error when I try get_inst_coverage and indeed $get_coverage()
    I'm using Incisive 6.2-s4
  • tpylant
     Nope, get_coverage is not yet supported in IUS.
    Tim
  • danlarkin
    ok, I guess I'll work around it.
     I'm also seeing errors with I try to define illegal_bins and/or ignore_bins in a cross? I'm getting an error message saying that "Currently illegal_bins and ignore_bins are not supported" which would be fair enough if  I could define what  crosses were legal, but when I try :
    cg_all : cross a, b {
      bins a1 = binsof(a) intersect { 1:2 };
      bins a2 = binsof(b) intersect { 0:7 };
    I get an error message saying: Bins declaration is not supported in cross
    So how does one specify a cross where not all bins are valid?
  • tpylant
    Transition bins, including ignore_bins and illegal_bins, are in beta now and will be released in IUS82 which is scheduled for December.
    Tim
  • tpylant
    The intersect construct is supported in the current release, IUS81.
    Tim
  • danlarkin
     Ok, thanks for clarifying that. So  if I'm understanding correctly, with IUS 6.2 there is no facility to specify legal/illegal bins in a cross?
  • tpylant
    Correct. However, you might be able to accomplish it post simulation by doing some filtering in ICCR (included with IUS) or vManager.
     Tim
