  2. Functional Verification
  3. IUS trasition coverage problem
  • Subscribers 66
  • Views 14780
ceesam
ceesam over 17 years ago
Hi
 Am using IUS 6.20-s007 (I have to use this) and I have the following code to perform transition coverage
cmd_trans : coverpoint m_curr_req_transact.m_cmd {bins illegal[] = (IDLE => IDLE);}
I followed an example from a Doulos tutorial
http://www.doulos.com/knowhow/sysverilog/tutorial/constraints/
The first compile error was as follows:
                                  Range specification for bin must start with ( ' { ' )
So I changed the code to:
cmd_trans : coverpoint m_curr_req_transact.m_cmd {bins illegal[] = {IDLE => IDLE};}
again the compile failed with:
                                            Range specification for bin must end with ( ' } ' )
I believe this to be a problem with IUS.  Any advice?
  • Shalom B
    Shalom B over 17 years ago
    Why do you have a left square bracket after "illegal"?
     Shalom
  • ceesam
    You are correct as the brackets are not required.  I have removed them but I still have the same fail
  • Shalom B
    How does it look now?
    Is IDLE visible in the scope of the coverpoint?
    What is the definition of m_cmd?
     Shalom
  • ceesam
    cmd_trans : coverpoint m_curr_req_transact.m_cmd {bins illegal = (IDLE => IDLE);}
     This is correct syntax.  It would appear to be an IUS 6.2 issue.
  • tpylant
    tpylant over 17 years ago
    Transition bin coverage is not support until IUS82, currently in beta. One workaround is to create an assertion or RTL to detect the transition and then cover that element.
    Tim
