  2. Functional Verification
  3. Troubleshooting IFV
  • Subscribers 67
  • Views 19868
Troubleshooting IFV
JASK
JASK over 18 years ago
    I am new to IFV. I was trying to run the tutorial example (given in ifvtut1 in the docs), but I am facing some errors even at that point.
cd examples/ifv
ifv -f fifo_cntl.f +gui
IFV seems to compile the .vhdl file properly, and is about to launch the GUI window, when an error appears.
formalverifier: *E,STRPIN:Could not initialize SimVision connection: SimVision process terminated before a connection was established.
When I try without the +gui option too, it gives me an error.
formalverifier: *E,URSYST: Unrecognized system task (did not match built-in or user-defined names) $get_simulationscratch.
Has anyone come across this before? I would really appreciate any help in fixing this.
-Jayanand
PS: It's a university tool. Could it be an installation bug?
  • CrazyForFormal
    CrazyForFormal over 18 years ago
    Jayanand
    Can you share the platform and version of OS you are running on?  I want to make sure you are running on a supported OS first.
    You can also run "ifv_check".  This utility will check to ensure you are on a supported platform.  You are looking for an overall Pass from this untility.
    Jose
  • CrazyForFormal
    I quickly confirmed that the tutorial runs fine for me.  Let's see the report from ifv_check.
    Jose
  • tpylant
    tpylant over 18 years ago
    Message
    It would be helpful if you include what version you are using.
    Although it has been fixed in the latest releases, there was a problem if you got your IFV and IUS installation paths mixed. This would happen if you have your IUS path first. What happens is that you call IFV (that doesn’t exist in the IUS release) and so it gets the IFV executable from the IFV release directory. But then you call SimVision that does exist in the IUS release and so it gets a different version from the IUS release directory.
    Tim
  • JASK
     Tim and Jose: Thanks for the prompt response.
    I am running the tool on a Red Hat Linux system (version 5.2 I think).
    IFV and IUS are both version 6.1. I am copy-pasting the log file from ifv_check (see below). It looks like the IUS path is taking precedence for launching SimVision as Tim suggested.
     Could you guys take a look and confirm this?
    Jayanand
    ifv_check : (c) Copyright 1995-2007 Cadence Design Systems, Inc.
        Usage:
             ifv_check -help
                 To get information and help about the script
                              Installation Check:
    IFV Installation hierarchy:
    TOOL: ncvhdl 06.11-s012 /apps/Linux/cadence-2008/IUS61
    TOOL: ncvlog 06.11-s012 /apps/Linux/cadence-2008/IUS61
    TOOL: cfe 06.11.012-s(06.11.s012) /apps/Linux/cadence-2008/IUS61
    TOOL: ncelab 06.11-s012 : /apps/Linux/cadence-2008/IUS61
    TOOL: hal 06.11-s012 /apps/Linux/cadence-2008/IUS61
    TOOL: simvision 06.11-s012 /apps/Linux/cadence-2008/IUS61
                   ##  Installation check failed, Status is: FAIL  ##
                   ## tools are being picked from multiple         ##
                   ## installation hierarchy.                      ##
                   ## Please fix this by having the IFV            ##
                   ## installation only in your envirnment.        ##
                   ## Fix Path and LD_LIBRARY_PATH or source       ##
                   ## ifv_setup from the IFV hierarchy             ##
    ******************ERROR******************
    Could not find checkSysConf
    Please set your Path to the IFV hieracharcy or source ifv_setup
    Log is saved as /tmp/ifv_check.eelnx10-2008.10.29.17:48.log
  • CrazyForFormal
    Jayanand
     The answer is in the output you appended.  As you can see the IUS path is first.  You need to put the IFV path first or have it be the only tool in your path.  Once you correct this, run ifv_check again to ensure your system is supported.  I believe IFV 6.1 was not supported on Redhat 5.  You will need to find a Redhat 3 or 4 system to run on.  If you can, upgrade to IFV 8.1 (same for IUS 8.1) as this version will run on Redhat 4 and 5.
    Hope this helps
    Jose
  • JASK
    Our tech guys used the info you provided here and corrected the path ordering . Now the tutorial works fine for me. The OS being Redhat 5 is not causing any trouble as of now.
     Thanks a lot for your help.
    -Jayanand
