  2. Functional Verification
  3. ICCR : How to generate functional cov report in .html format...
  • Subscribers 67
  • Views 18126
ICCR : How to generate functional cov report in .html format ,i get it in .data
Pooja
Pooja over 18 years ago
Hi I use iccr tool Version 08.10-s006 to generate coverage.My Makefile roughly shows up as follows
+nccovdut tx_rx +nccoveragfe+all +nccovworkdir+COVDIR
At the end of simulation I get the coverage report at XX/COVDIR/design/test/icc.data
The icc.data is not readable and thus compels us to use gui to check the coverage report.
can you help me generate a coverage report in .html or .txt format using iccr ?
I used the following steps
iccr> load_test XX/COVDIR/design/test
iccr> report_html *
iccr>exit
This indeed gives a report as iccr.log but this report is clubbed with lot of irrelevant information such as the commands given to generatre this report and stuff like that
My goal is to generate a Coverage report in html format or convert the existing .data file in .html or .text which ever is better.Please help!!!!!!!!!!!
  • Mickey
    Mickey over 18 years ago
     Hi Pooja,
    What you need to do to send the report to an appropriate file output is add the unix redirect command when you execute the report_html command, eg.  report_html * > output.html.
    Please let me know if that helps.
    Best regards,
    Mickey
  • Pooja
    Pooja over 17 years ago
    Mickey said:
     Hi Pooja,
    Best regards,
    Mickey
  • Pooja
    Hi Mickey ,
          Your solution works!!!!!!!!!! thanks a lot!!!
    Pooja
