  2. Functional Verification
  3. Specman cover : cross of transition items
  • Subscribers 67
  • Views 17497
harip
harip over 17 years ago
Hi All,
 I have a query regarding specman coverage implementation.
If we have item A and item B for coverage and we define transition on the same
transition A;
transition B;
Can we cross transition__A ,transition__B for covering
     A          B
 0->1       1->0
1->0        0->1
0->0        1->0   etc.
 Please suggest if it can be done or is there some other way.
Hari
  • hannes
    hannes over 17 years ago
    When you need to define a transition you can give it a name and then just cross it, i.e.
    struct foo {
       a1: bool;
       b2: bool;
       event cover_me;
       cover cover_me is {
          item a1 using no_collect=TRUE;
          item b2 using no_collect=TRUE;
          transition a1 using name=a_trans, no_collect=TRUE;
          transition b2 using name = b_trans, no_collect=TRUE;
          cross a_trans,b_trans;
    -hannes
  • harip
    Hi Hannes,
    Thanks for the prompt response.
    Does cross of trans_items at a defined cover event will give the possible simultaneous transition of both the items.
    Am I correct. Please suggest if it is other way around.
    Hariprem
  • hannes
    Hello Hariprem,
    I'm not sure I understand your question. Please can you elaborate the question and
    maybe give a samll example of what you want to achieve.
    -hannes
  • harip
     Hi Hannes,
     Let us take an example. we want to cover
    1. bufferable read followed by bufferable write
    2. bufferable write followed by non-bufferable read etc (so on possible combinations)
    As here we have two items to cover : i) buff_non-buff  ii) operation(RD, WR)
    So at the end of transaction, we want to take care that point (1) & (2) are covered.
    Please suggest if it is possile via crossing the transitions of buf_non-buff and operation.
    Hariprem
  • hannes
    Hello Hari,
    yes, crossing the transition of both will give you the desired answer.
    -hannes
  • harip
     Hi Hannes,
    Hariprem
