  2. Functional Verification
  3. can't run IFV under GUI mode
  • Subscribers 67
  • Views 3799
arthurwu
arthurwu over 17 years ago
i wanted to run IFV under GUI mode, but encountered some problem, the error log as following, please help, thank you!
by the way, i can run simvision under GUI mode.
error log:
ifv: 06.20-s004: (c) Copyright 1995-2008 Cadence Design Systems, Inc.
simvision: 06.20-s004: (c) Copyright 1995-2008 Cadence Design Systems, Inc.
Error initializing application
Application initialization failed: window type "checkset" is not defined
SimVision process terminated before a connection could be established.
formalverifier: *E,STRPIN: Could not initialize SimVision connection: SimVision process terminated before a connection was established..
  • JoergM
    JoergM over 17 years ago
    Hi Artur,
    this sounds like a environment issue: IFV is picking up SimVision from an IUS installation. Can you check your $PATH variable and make sure the IFV installation is not corrupted?
    If that does not help try removing your ~/.simvision directory and start again.
    Joerg.
  • arthurwu
    Hi, Jogerg,
      Thank you for your help. it's strange because other one can run IFV under GUI mode. i have checked my PATH variable, it's ok. and i can also call simvision under tcl mode in FormalVerifier, just can't run ifv with arg "+gui".
      removing ~/.simvision does not help.
  • JoergM
    Hi Artur,
    I recommend to contact your Cadence AE at sourcelink or support.cadence.com to do some further analysis. I never heard of a case like this.
    Joerg.
  • tpylant
    tpylant over 17 years ago
    Arthur,
    Did you use 'which simvision' to verify that you're getting simvision from the IFV release?
    Tim
  • arthurwu
    Tpylant,
       yeah, you got the key. i didn't recognize that i should use simvision from the IFV release other than IUS release.
       thank you very much:)
