  2. Functional Verification
  3. Verification Plan using Eplanner
  • Replies 19
  • Subscribers 67
  • Views 25482
Manish Verma
Manish Verma over 17 years ago
 Hi....
Can anybody explain me How to map checkers(check that statement) into vplan using eplanner?
Thanks!
  • ckomar
    ckomar over 17 years ago
    I am going to assume that you are already writing out coverage data from Specman and can import that to Enterprise Planner. Assuming this, you will also need to enable Specman to write out these checks to the database.This is not done by default but can be accomplished with the following config command
    config cover -collect_checks_expects=TRUE
    Once you have done this, the checks will appear in the model file (.ucm) and can be mapped in Enterprise Planner.
    Hope this helps,
    Chris
    archive over 17 years ago
    Since I am not sure exactly which step wasn't clear I will try to sum all. Please feel free to contact me if you need further assistance.
    1) The first step is to make sure you are collecting those checks (use the command Chris wrote).
    2) Use Specman and eplanner 8.1 or above.
    3) When you execute a simulation with vmanager (desktop or enterprise), coverage database files are created. Depends on the version/tools you are using, you should see those files under the simulation result directory under model_dir directory. The files will have extensions *.ucm and/or *.model. Please make sure you know where to find these files and that you indeed have them in your simulation directory.
    4) Now in eplanner you are ready to import these coverage data files for mapping of coverage,checks and directed tests. Go to the
    "implement" tab and click import coverage. Choose all the *.ucm/*.model files you have in the relevant simulation directory. You will now get a coverage tree in eplanner in which you can browse through the various coverage/checks/testcases items and choose what you want to map. Checks from Specman will be part of that obviously.
    5) Chick on the desired check and the desired item in the plan and click "map to vplan"
    There is more information in the  docs but also feel free to contact me at ilanag@cadence.com
  • Manish Verma
    Thanks Chris/Ilana for the information.
    I am getting one error:
    Doing setup ...
       *** Error: 'collect_checks_expects' coverage option cannot be changed when
    files are loaded/compiled into Specman
                    at line 169 in @cdn_i2c_env_h
            set_config(cover, collect_checks_expects, TRUE);
    Where to give this command for "collect check expects". I have written  under sys and using setup method.
    like this:
    extend sys {
        setup() is also {
    }; -- extend sys
    Thanks & Regards
    Manish
    Hi Manish,
    The easiest way is to define this in the SPECMAN_PRE_COMMANDS since the idea is the have this config before any e is loaded.
    I would have in my run script something like:
    #!/bin/sh
    SPECMAN_PRE_COMMANDS=”conf cover –collect_checks_expects=TRUE”;
    Export $SPECMAN_PRE_COMMANDS
    Specman –c “load $WORKAREA/my_test.e; conf cover –database_format=ucd –write_model=ucm; test”;
    Hope this helps!
    Ilana.
  • Manish Verma
    Hi Ilana.,
    I am using this for CMS. So, Where can I add these commands(In brun scripts?)?
    Thanks!
    Manish
    Hi Manish,
    You should have a file <vip>_ brun_pre_session_script.sh for example vr_ahb_brun_pre_session_script.sh there you can change the pre_session command.
    Hope this helps,
    Ilana.
  • Manish Verma
    Hi Ilana,
    I changed my  <vip>_ brun_pre_session_script.sh like this:
    run_excov.pl -top_files $BRUN_xxx_VE_FILES -append_to_vsof -verbose;
    SPECMAN_PRE_COMMANDS="conf cover -collect_checks_expects=TRUE"; --added commands
    export $SPECMAN_PRE_COMMANDS --added commands
    # CREATE STUB FILE AND COMPILE VERILOG FILES
    if [ $BRUN_xxx_E_MODE = compiled ]
    then
        # Compile the enviroment files (ve_files)
        sn_compile.sh -shlib -exe $BRUN_xxx_VE_FILES -o test_suite_compile;
        # create verilog stub file
        test_suite_compile -c "write stub -ncvlog specman.v";
    else # interpreted mode
        --added commands
        specman -c "load $BRUN_xxx_VE_FILES ; conf cover -database_format=ucd -write_model=ucm; write stub -ncvlog specman.v";
    fi
    But after running the demo for CMS, It's only collecting the coverage items not "check that" statement which I have written for the protocol checker.
    What can be the issue?
    Thanks!
    Manish
     Hi Manish,
    2 comments that might help:
    1. why you are still using the run_excov.pl? this is rather an old fashion way to generate the coverage model. starting 6.2 this is not necessary and you can use the Unicov coverage database. which version are you using?
    2. Here is a run script I use to generate checks:
    • #!/bin/sh
    • SPECMAN_PRE_COMMANDS="conf cover -collect_checks_expects=TRUE;conf gen -seed=$BRUN_SEED;$SPECMAN_PRE_COMMANDS";
    • export SPECMAN_PRE_COMMANDS;
    • specman  -c "load my_test;conf cover -database_format=ucd -write_model=ucm;test" ;
    Efrat
  • Manish Verma
    Hi Efrat,
    I tried these commands but still it's not working. I am using 8.1 version.
    Thanks!
    Manish
  • ckomar
    Hi Manish,
      I also want to make sure you're using 8.2 software. This is the only version of Enterprise Manager that will enable you to see check status in the vPlan view.
    Chris
