  2. Functional Verification
  3. instance based functional coverage on systemverilog classes...
  • Subscribers 68
  • Views 16163
instance based functional coverage on systemverilog classes (OVM) in vManager
FrankE
FrankE over 17 years ago
 Hi all,
I am just checking vmanager functionality and found out, that, when instantiating a class twice in OVM, I don't get separate coverage reports for these 2 instances. Unfortunately neither docu nor help etc. tell me, whether this is/will be supported.
For me, this is currently a NoGo-criteria, as I have several verification-IPs of one class instantiated on different data-channels.
This might also be a  problem of verification-recording as I see the same in ICCR. Any information about workarounds or fixes ?
regards, Frank
  • tpylant
    tpylant over 17 years ago
    This is a current limitation with having your coverage within a class. This is a high priority item to be fixed.
    Tim
  • DDXYZVV
    DDXYZVV over 17 years ago
     You are right.. But If I take instance of two module then how to see coverage for those two instace in vmanager?
     Any idea?
