  2. Functional Verification
  3. error when passing a string to ncutils
  • Replies 13
  • Subscribers 68
  • Views 22629
JMGGL
JMGGL over 17 years ago
This is what I am trying to do:
parameter [1023:0] chip_name="tb_top.I_0.";
wire [1023:0] path_name;
assign  path_name    = {chip_name,"module1.module2.signal"};
$nc_mirror("signal",path_name","verbose");
*And the following message error appears:
Non-string argument specified for $nc_mirror task...
I tried to pass directly  path_name, without concatenation, and same problem. Also with other ncutils: nc_force, nc_release... Does anybody know how to do it?
Thanks in advance.
  • tpylant
    tpylant over 17 years ago
    Yes, the problem exists with the latest version of IUS61 and IUS62. However, it does work in all current versions of IUS81 and IUS82. Tim
  • adua
    adua over 17 years ago
    The argument of $nc_mirror can be string or a register. Now, when it is a string, it should be the hierarchical path of the object. When it is a register then it has to be the 'actual' register. Here you are trying to pass a register whose value is expected to be treated as a string.
    So, you need to either declare a string as already suggested in this thread.
     Or the other simpler way is to avoid the path_name completely. I mean, instead of first filling a path_name variable with the actual hierarchical path, pass the hierarchical path directly as string in nc_mirror argument. Please see the example below that shows this (It works with IUS6.11 version and don't need any string SV datatype).
    //1.v file
    module tb_top ();
      reg [1023:0] path_name; wire signal;
      io I_O ();
    //assign path_name = {chip_name,"module1.module2.signal"};
      initial begin
      $nc_mirror("signal","tb_top.I_O.module1.module2.signal","verbose");  //This works.
      //$nc_mirror("signal",path_name,"verbose");  //reg to be treated as holding string value. This WOn't work.
      end
    endmodule
    module io;
     m1 module1 ();
    endmodule
    module m1;
     m2 module2 ();
    endmodule
    module m2;
     wire signal;
     reg r;
     assign signal = r;
     initial begin
      #10 r = 1'b1;
      #10 r = 1'b0;
      #10 r = 1'b1;
     end
    endmodule
    //end 1.v
    Now, Run as follows: (6.1 is fine)
    > irun 1.v -access +r
  • JMGGL
    Thanks everybody!
    Problem solved using System Verilog and moving to IUS8.2, as tpylant suggested.
    Now I have another problem when passing an string values to $nc_force during runtime. This is what I'm trying to do:
    *Option 1:
    reg [2:0] counter;
    always @(posedge HCLK or negedge HRESETn) begin
    begin
      if (!HRESETn) begin
        block_count <= 3'd5;
      end
      else
        $nc_force("path", "#block_count","verbose");
        block_count <= block_count+1;
      end
    end
    *Option 2:
    reg [2:0] block_count;
    begin
      if (!HRESETn) begin
      end
      else
        var_force= {"3'd",uitos(block_count, 10)};
        $nc_force("path", "#var_force","verbose");
      end
    end
    function string uitos; // returns string values
    begin
      input [31:0] number;
      input [31:0] base;
      string str;
    end
    ncsim reports that is forcing the 3'd5 value in both cases, but then an Internal Error occours.
    Log file in both cases:
    The value 3'd5 has been forced on object <path>
    *** glibc detected *** ncsim: double free or corruption (!prev): 0x190e3198 ***
    ======= Backtrace: =========
    /lib32/libc.so.6[0xf7e4c8d2]
    /lib32/libc.so.6(__libc_free+0x87)[0xf7e4df67]
    ncsim[0x87a9a16]
    ncsim[0x87a9c21]
    ncsim[0x83dd526]
    [0xc0d4edc]
    ======= Memory map: ========
    fff31000-fffab000 rwxp fff31000 00:00 0                                  [stack]
    ncsim: *F,INTERR: INTERNAL ERROR
    Observed simulation time : 1365 NS + 16
    The tool has encountered an unexpected condition and must exit.
    Contact Cadence Design Systems customer support about this
    problem and provide enough information to help us reproduce it,
    including the logfile that contains this error message.
      TOOL: ncsim   08.20-s002
      HOSTNAME: Simulator11_bcn
      OPERATING SYSTEM: Linux 2.6.19-gentoo-r5-BigSim-RAID1-lm_sensors #2 SMP Sun Apr 1 16:31:53 CEST 2007 x86_64
      MESSAGE: Unexpected signal #6, program terminated (null)
    Any idea how to do that? Or any other way to force values in verilog during runtime?
