  2. Functional Verification
  3. error when passing a string to ncutils
  • Replies 13
  • Subscribers 68
  • Views 22628
JMGGL
JMGGL over 17 years ago
This is what I am trying to do:
parameter [1023:0] chip_name="tb_top.I_0.";
wire [1023:0] path_name;
assign  path_name    = {chip_name,"module1.module2.signal"};
$nc_mirror("signal",path_name","verbose");
*And the following message error appears:
Non-string argument specified for $nc_mirror task...
I tried to pass directly  path_name, without concatenation, and same problem. Also with other ncutils: nc_force, nc_release... Does anybody know how to do it?
Thanks in advance.
  • JMGGL
     Sorry, I would say "$nc_mirror("signal",path_name,"verbose");", without the extra character.
  • Shalom B
    Shalom B over 17 years ago
    How about $nc_mirror("signal",{"\"",path_name,"\""},"verbose"); ?
     Shalom
  • JMGGL
    Thanks for your quick reply, but still not working...
  • tpylant
    tpylant over 17 years ago
    When I displayed the path_name wire, it was empty:
    initial $display("signal %0s",path_name);
    However, if I made the path_name a reg and assigned it within an initial block, the display was correct:
    reg [1023:0] path_name;
    initial  path_name    = {chip_name,"module1.module2.signal"};
    Can you use a reg instead of a wire?
    Tim
  • JMGGL
    Thanks Tim, but still with same issue: Non-string argument specified for $nc_mirror task...
    You were right when you said that the path was empty, so I fixed it.
    Now I mixed your solutions:
    initial  path_name    = {"\"",chip_name,"module1.module2.signal","\""};
    With initial $display("signal %0s",path_name),  the path seems to be correct:
    "tb_top.I_0.module1.module2.signal"
    Any other idea?
  • Mickey
    Mickey over 17 years ago
    How about using the string datatype as follows:
    string chip_name = "tb_top.I_0.";
    string path_name;
    string full_path;
    initial
      begin
        path_name = "module1.module2.signal";
        full_path = {chip_name, path_name};
        $nc_mirror("signal", full_path, "verbose");
      end
    Hope that helps.
    Mickey
  • JMGGL
    Thanks Mickey.
    string datatype is used in System Verilog right? How to enable it with ncsim 6.11? I tried with ncvlog -sv and it doesn't work.
    Other options to solve my problem using normal Verilog? This is really important for me, since my database has plenty of those assignments...
  • JMGGL
    No chance using string from System Verilog datatype.
    ncvlog_cg: *W,NOSTRA: Non-string argument specified for $nc_mirror task at Line...
    ncutils doesn't support the way to introduce signals as input parameters.
  • tpylant
    I was able to get it to work using the SV string datatype:
    file test.sv
    module test;
    parameter /*[1023:0]*/ string chip_name="test.";
    wire signal;
    wire x,y;
    /*reg [1023:0]*/ string path_name = {chip_name,"module2.a"};
    module2 module2 (.a(x), .b(y));
    initial begin
      $display("%0s",path_name);
      $nc_mirror("x",path_name,"verbose");
    end
    endmodule
    file mod2.vhd
     library IEEE;                       -- IEEE library
    use IEEE.std_logic_1164.all;        -- Reference the Std_logic_1164 system
    use IEEE.numeric_std.all;           -- Reference numeric standard package
    entity module2 is
      port(
        a   : in  std_logic;
        b   : out std_logic
    end module2;
    architecture rtl of module2 is
      --signal data_bus_valid   : std_logic;
    begin
      b <= a;
    end rtl;
    % irun -access rwc mod2.vhd test.sv
    Although the string datatype is supported in IUS61, the above code did not work until IUS81.
    Tim
  • JMGGL
    So the problem is the current version of NC-Verilog, since the string problem appears when I have compiled/elaborated your code with irun.
    Strange, since it seems to be last Cadence version.
    irun: 06.11-s011: (c) Copyright 1995-2008 Cadence Design Systems:
    ncvlog_cg: *W,NOSTRA: Non-string argument specified for $nc_mirror task at Line: 14 in File: ./test.sv.
    Thanks Tpylant.
