  2. Functional Verification
  3. Temporal expression in e
  • Subscribers 67
  • Views 16234
spark
spark over 17 years ago
Hi All,
When I use "expect" to do the timing check, "=>" operator is used in "expect", but "=>"will have one cycle delay, for example
@a => {[1];  @b}; then event b has two cycles delay than event a, if event b can be the same time as event a how to check it?
expect  @a => {[..]; @b;} only indicates event b is later than event a, can not include event b can occur same time as event a.
  • mstellfox
    mstellfox over 17 years ago
    Hi Spark,
    Can you write down the english expression of what you want to check?  It is not clear from your description below.
    Is this what you want to check:
    If event a occurs, then b must occur on the same cycle as a or any number of cycles after a
    Or do you need to check something else??
    Mike
  • spark
    Sorry for my poor explanation.
    Yes. I use following expression, but it does not include same time situation.
    expect @a => {[..]; @b};
  • mstellfox
    Ok, then you need one temporal expression to capture the case when @a and @b occur on the same cycle, as well as the case when the don’t occur on the same cycle.  See below – I think this will work for you.
    expect (@a and @b)@clk or ((@a and not @b) => {eventually @b})@clk;
    Mike
  • spark
    Thanks for your reply.
    In another case, if I want to check event b is delay N cycles after event a, N is a signal in HDL code and range of N is >=0. Can I use this kind check, I wonder whether I can use "if else" here.
    if ("N" == 0)  {
        expect (@a and @b);
    else {
       expect @a => {["N"-1]; @b};
  • mstellfox
    First, I would read the “N” signal value to a simple_port and use the simple_port in your temporal expression.  Below, I assume that the “N” signal value will not change during the evaluation of the temporal expression, and then I think this will work:
    extend sys {
                n:         in simple_port of uint is instance;
                event clk is @sys.any;
                event a;
                event b;
                event a_n_is_0 is true(n$ == 0)@a;
                event a_n_greater_0 is true(n$ > 0)@a;
                expect (@a_n_is_0 and @b)@clk or
                                ((@a_n_greater_0) => {[n$ - 1];@b})@clk;
    Mike
