  2. Functional Verification
  3. cannot run simvision
  • Subscribers 67
  • Views 19481
bdatta
bdatta over 17 years ago
 I have verilog-XL simulator from the IUS5.8 release and Allegro from the SPB16.01 release.  I can run Allegro but when I try to run verilog-XL it fails when it tries to start simvision and gives the following strange error message:
Cadence/tools/verilog/tools/bin/64bit/simvision: line 62 Cadence/tools/verilog/tools/bin/64bit/simvision.exe: cannot execute binary file
Cadence/tools/verilog/tools/bin/64bit/simvision: line 62 Cadence/tools/verilog/tools/bin/64bit/simvision.exe: success
simvision proccess terminated before connection could be established
Allegro is installed in 'Cadence' directory and the IUS5.8(verilog-XL) is installed in the Cadence/tools/verilog directory
  • StephenH
    StephenH over 17 years ago
    Hi.
    I'm not familiar with Allegro, but I wonder if it has some binaries that have the same name as Verilog-XL does?
    Whenever I have to debug application problems, the first thing I do is start a new xterm and clean the PATH and LD_LIBRARY_PATH variables to remove everything except the very basic Unix directories like /usr/bin and /bin.
    After doing this, set the absolute minimum set of variables to configure Verilog-XL, in this case:
    > setenv PATH Cadence/tools/verilog/tools/bin:$PATH
    > setenv LD_LIBRARY_PATH Cadence/tools/verilog/tools/lib:$LD_LIBRARY_PATH
    Now try running a few components of the simulator to see if it's working:
    > ncsim -version   (check the tool is on the PATH)
    > cdnshelp   (opens the help GUI)
    > checkSysConf IUS5.8      (tests that your OS is compatible with the simulator)
    > simvision
    If simvision still fails to start after cleaning your environment as above,check the results of the checkSysConf command to be sure there are no failures in the compatibility with your OS. If you're still stuck, please email support@cadence.com and one of the support staff will ensure your problem gets resolved.
    By the way, you said Allegro is installed in the "Cadence" directory - do you mean that IUS is installed inside the Allegro installation?
    That would be a bad thing to do - each product expects to have a clean and separate installation area.
    Best would be something like:
    Cadence/Allegro/16.01/
    Cadence/Verilog/5.8/
    Good luck :-)
    Steve.
