  2. Functional Verification
  3. IUS 8.2 internal error
  • Subscribers 67
  • Views 15755
Chintanm
Chintanm over 17 years ago
Hello Cadence guys,
When I try to use a variable of type real to give delay as #c ( where c is declared as real), then tool gives me internal error.
but when I use direct number for delay as #10.522  then tool is not giving any error.
Is there any solution for this?
Please reply ASAP.
- Chintan.
  • Mickey
    Mickey over 17 years ago
    Hi Chintan,
    What version are you using?  As an FYI, I am using 8.20-s003 and do not receive an internal error using a simple testcase.
    With that in mind I suspect the situation is either due to a bug in the version of the code  you are using, or the problem is a new one and only appears with the way the real is modeled in the testcase you are using.
    Can you send a small example illustrating the bug?
    Best regards,
    Mickey
  • Chintanm
    Hi Mickey,
    Thanks for the response.
    I am using IUS 8.20-b003 .
    I am also not able to regenerate the error in a demo code.
    What I am doing is :
    I am generating clock from one class which directly access's the signal of interface. and to generate that clock i have used variable of type real for delay.
    my code line looks like this:
    task clock ();
    real a;
    a =10.625;
    while (1) begin
    #a xyz_interface.clock = ~xyz_interface.clock; ( f I replace a with 10.625 then code works fine)
    end
    endtask
    The whole code is made with OVM 2.0
    Hope this information hepls to find some answer , meanwhile I am trying to make demo code with same error so you can have a look.
    - Chintan
    PS : I tried with variable of type int instead of type real and code worked. But I need to use variable of type real. Seems to have some problem with type real. any solution?
  • StephenH
    StephenH over 17 years ago
    Hi Chintan.
    IUS 08.20-b003 is a Beta testing release - you should not use it any more. The production releases of 8.2 are available from the Cadence downloads site http://downloads.cadence.com/.
    Steve.
