  2. Functional Verification
  3. PSPICE diode model parameters
  • Subscribers 67
  • Views 17209
Paul T
Paul T over 17 years ago
I am using a PSPICE model for the On Semi MUR1100E diode from the On Semi website that contains the following line:
 .model dqemod d (is=4.84474e-06 n=1.73125 eg=0.775998 xti=0.005)
What do the parameters mean?
  • oldmouldy
    oldmouldy over 17 years ago
    In the product installation there is a DOC directory, in the DOC directory, is a PSPCREF directory, in the PSPCREF directory is a pspcref.pdf, in there is what you need. Look for the section on Analog Components and in that section D for DIODE, under there will be all the model details including the parameter definitions and how they are used in the equations to model the device.
  • dezurtrat
    dezurtrat over 17 years ago
    Thanks. Sure helped me out... :)
