  2. Functional Verification
  3. where can i find the vr_ad package documentation
  • Subscribers 67
  • Views 15192
eyal
eyal over 17 years ago
hello all
the cadence  My Plan-to-Closure site doesn't seem to work any more is there any other way to get the vr_ad package  documentation ?
thanks Eyal
  • StephenH
    StephenH over 17 years ago
     Hi Eyal.
    Cadence has not withdrawn the plan-to-closure web site, it might just have had a glitch when you tried it, and it's working for me as I type.
    You can also get to the docs via http://sourcelink.cadence.com/ - you can enter vr_ad in the search criteria, but make sure you chose only to search the product documentation, not the app notes etc, else you may get some misleading hits.Ultimatelyit should link you to http://sourcelink.cadence.com/docs/files/Release_Info/Docs/ipcm_utilities/ipcm_utilities8.2/ipcm_utilities.pdf
    Finally, I assume you have IPCM installed, if you're using vr_ad! If you've got version 8.1 or later, you can use "start_kit" as a Linux command to open the help browser for IPCM. I can't remember the command for older versions of IPCM, maybe someone else can reply with that info (I'm away from my Linux box at the moment).
     Hope this helps!
    Steve.
  • eyal
    thank you i just downloaded it
    best  Eyal
