  2. Functional Verification
  3. System Verilog Functional Coverage using NCSIM
  • Replies 8
  • Subscribers 68
  • Views 27130
ndalia
ndalia over 17 years ago
 Are there any specific commands that are available for dumping functinoal coverage which would generate some report at the end of simulation? Currently I'm using Verdi to view the waveforms.
  • Mickey
    Mickey over 17 years ago
    Hi Ndalia,
     If you add the following tcl command to ncsim, the tool will send the results of the assertions to the log file at the end of the simulation.
     assertion -summary -final
    Let me know if that helps.
    Best regards,
    Mickey
  • ndalia
    Hi Mickey,
     I am not using assertions based cover statements instead I'm using covergroups [with coverpoints & bins] to generate functional coverage at top level simulation which I trigger at a specific event in the test bench. Like for assertions based coverage I use $fsdbDumpSVA and verdi would then display all the required info.
    -Nishit
  • Mickey
     Hi Nishit,
    Mind if we take this offline so I can understand the exact functionality of $fsdbDumpSVA so I can recommend something similar?
    Sounds like you are expecting data-oriented functional coverage.  Is the result with $fsdbDumpSVA a dump to the fsdb waveform database?  Or possibly a different type of database, like a coverage related database for example?
    Please feel free to email me directly at jrodrig@cadence.com.
    Best regards,
    Mickey
  • Mickey
     Hi Nishit,
    To dump functional coverage of covergroups/coverpoints add "-coverage functional" to your elaboration command line.  The result will be a coverage database in a directory named cov_work.  You would then use iccr to analyze the results of the coverage.
    You can get more specific information on using iccr and coverage in general by reviewing the ICC User Guide within the IUS installation.
    Please feel free to email me (jrodrig@cadence.com) if you have any questions.
    Best regards,
    Mickey
  • JonB
    JonB over 9 years ago
    For using the Cadence simulator solution, the switch argument for the -coverage option is no longer 'functional', but rather 'u', for indicating to add functional coverage recording to the simulation snapshot
    UNIX> irun -coverage u ......
    OR
    UNIX> ncelab -coverage u .....
    An alternative is to place the request into the Coverage Configuration File (CCF) as follows:
    select_functional
    select_coverage covergroup
    The tool is informed of the location of the CCF by use of the -covfile <path to CCF> command line switch.
    UNIX> irun -covfile ../../coverage/my.ccf ....
    OR
    UNIX> ncelab -covfile ../../coverage/my.ccf ....
    The analysis tool is no longer 'iccr', but is replaced by 'imc'.
  • mukukr
    mukukr over 5 years ago
    I am new to the Xcelium tool, I am using an Xcelium tool, I wanted to enable or dump coverage (functional + code) for my testbench, please help me w/ the command to enable/dump/open the coverage.
    thanks
  • mukukr
    mukukr over 5 years ago in reply to Mickey
    thanks
  • mukukr
    mukukr over 5 years ago in reply to JonB
