  2. Functional Verification
  3. vr_ahb read data when response is ERROR
  • Subscribers 68
  • Views 16412
spark
spark over 17 years ago
Hi all,
I found the AHB eVC's read data has problem when the reponse is ERROR.
For testing a AHB master, I add an active AHB slave in eVC config file. For tracing the transfer I realize a simple scoreboard to recordthe transfer data like below.
extend AHB SLAVE vr_ahb_agent_monitor {
    on tr_ended {
        if (cur_transfer.kind is not in [IDLE,BUSY]) {
            sys.scbd.record(cur_transfer);
I found when cur_transfer is READ and HRESP=ERROR, the HRDATA will become to zero but I checked the HDL waveform, the HRDATA is not zero, I dont know why eVC return the error read data when resp is ERROR.
  • Misha Moroshko
    Misha Moroshko over 17 years ago
    Response = ERROR means that the slave could not answer with data, i.e. the rdata value that you see on the bus is probably randomized.
    I would suggest you to collect transfers in the scoreboard only if the slave responded with a valid data, i.e. only when the response is OKAY.
  • spark
    Thank for your reply.
    Allthrough the rdata value may be randomized but I am strange that why the rdata collected by scoreboard is different with rdata in hardware. I think the rdata in hardware is also generated by eVC it should be same as data colected by scoreboar.
  • Misha Moroshko
    I understand what you are saying.
    It seems reasonable that the monitor should collect the data that appears on the bus.
    I will open a CCR for that.
    Thanks !
    BTW, you are not stuck with implementing the scoreboard, right ?
  • spark
    I can use the hardware signal directly but I think it is not good. Now I fix the reponse to OKAY to ignore this problem.
