  2. Functional Verification
  3. Coverage result comes in grey colour
  • Subscribers 67
  • Views 14805
SpecMAN INFANT
SpecMAN INFANT over 17 years ago
 Why does the coverage graph of the coverage browser in specma come in grey colour instead of green? Is it because the number of ranges defined for an coverage item is large, if then what is the maximum number of ranges that can be defined so that the coverage result comes in green colour?
  • StephenH
    StephenH over 17 years ago
    It would help if you shared an example of the coverage definition that's causing your problem...
    Usually items are grey if they are deemed to be ungradeable, i.e. too many different values in a single bin, as you suggested in your question.
    If you look in the Specman docs for "ungradeable items", you'll find a bunch of useful info: http://sourcelink.cadence.com/docs/files/Release_Info/Docs/sn_usage/sn_usage8.2/sn_usage.pdf
