  2. Functional Verification
  3. Functional coverage results varies in GUI and detailed ...
  • Subscribers 67
  • Views 15077
Functional coverage results varies in GUI and detailed report
dvshah
dvshah over 17 years ago
Functional coverage results are varies in GUI and coverge summary report.  I am getting diffrent % functional coverage. I merged 2 regression data to generate merged report.
Please let me know if you encounter this problem before.
Please suggest me possible solution.
dvshah
  • Mickey
    Mickey over 17 years ago
    Hi dvshah,
    That certainly seems confusing.  Can I suggest opening a service request with customer support (support@cadence.com)?
    can you also answer the following questions:
    when looking at an unmerged report are you seeing different reports btw summary and gui or is the situation only seen with merged reports?
    are you seeing the different numbers in the iccr gui or between iccr and vmanager?
    does any of the tests include manual marking or set_com?
    are the functional coverage numbers related to assertions, systemverilog covergroups, or both?
    what version of ius are you using (output of "ncvlog -version")
    best regards,
    Mickey
