  2. Functional Verification
  3. Randomizing object-arrays: IUS 8.2s003 ncvlog ERROR *EX...
  • Subscribers 66
  • Views 15120
Randomizing object-arrays: IUS 8.2s003 ncvlog ERROR *EXPRDV
cubicle82
cubicle82 over 17 years ago
I can't seem to run rand_mode() or constraint_mode() directly on an (indexed) element of an array.
Example:
module randfail;
class cls_randomer;
  rand int unsigned x, y;
  constraint con_x {
    x < 1000;
    x > 15;
constraint con_y { y < 100; }
endclass : cls_randomer
//cls_randomer randomer[] = new[5]; // dynamic array
cls_randomer randomer[5];  // non-dynamic array
initial begin : initial_begin
  static cls_randomer temp;
  // Init: shut off randomization of 'x' , later we'll re-enable them on  case-by-case
  foreach( randomer[i] ) begin : foreach_i
    temp = new();
    temp.rand_mode(0);
    temp.constraint_mode(0);
    temp.con_x.constraint_mode(1);
    randomer[i] = new();
    randomer[i].rand_mode(0); // ncvlog: *E,EXPRDV
    randomer[i].constraint_mode(0);
    randomer[i].con_x.constraint_mode(1);
//    randomer[i] = temp;
    $display("creating & randomizing object#%0d", i );
  end : foreach_i
end :initial_begin
endmodule : randfail
irun: 08.20-s003: (c) Copyright 1995-2008 Cadence Design Systems, Inc.
ncvlog: *E,EXPRDV (randfail.sv,29|24): Expecting a rand or randc variable as the prefix to the rand_mode task/function.
errors: 3, warnings: 0
Basically, I have to use a temporary (scalar) object to do the following:  run the built-in methods rand_mode() and constraint_mode() on the scalar-object, then assign the object back to the target element of my object-array.
  • tpylant
    tpylant over 17 years ago
    Looks like a current limitation in IUS. Your temp idea looks like the best solution:
      // Init: shut off randomization of 'x', re-enable them on case-by-case
        rand_off(randomer[i]);
        randomer[i].x.rand_mode(1);
        void'(randomer[i].randomize());
        $display("creating & randomizing object#%0d: x=%0d y=%0d", randomer[i], randomer[i].x, randomer[i].y);
      end : foreach_i
    end :initial_begin
    function void rand_off (output cls_randomer temp);
        temp = new();
        temp.rand_mode(0);
    endfunction : rand_off
     Tim
