  2. Functional Verification
  3. Coverage Item
  • Subscribers 67
  • Views 15017
Coverage Item
Manish Verma
Manish Verma over 17 years ago
I am facing one problem while writing the coverage item.
I have something like this:
These are the fields which I have to cover:
extend R test_unit {
    field_R: type1; --- two subtypes R0 and R1
    when R0 R test_unit {
        field_R0_1: uint;
        field_R0_2: bool;
    when R1 R test_unit {
        field_R1_1: uint;
        field_R1_2: bool;
I have one event transaction_end_e in monitor, where I need to collect the coverage item.
My coverage file look like this:
    cover transaction_end_e is {
        item field_R: type1 = tr.field_R;
    cover transaction_end_e using also when = (tr.field_R==R0) is also {
        item field_R0_1: uint = tr.as_a(R0 R test_unit).field_R0_1;
        item field_R0_2: bool = tr.as_a(R0 R test_unit).field_R0_2;
    cover transaction_end_e using also when = (tr.field_R==R1) is also {
        item field_R1_1: uint = tr.as_a(R1 R test_unit).field_R1_1;
        item field_R1_2: bool = tr.as_a(R1 R test_unit).field_R1_2;
Here, I am getting error as
 Error: struct is NULL - cannot access field 'R0'R'R'field_R0_1
What I think is that whenever the value of field_R is R1 then it is giving problem with R0 item and vice-versa.
Can anybody help me in finding the solution?
Thanks!
  • Hilmar
    Hilmar over 17 years ago
    Hi Manish,
    I'd extend the specific subtypes of your test_unit with coverage groups, something like this:
    extend R0 test_unit {
        cover transaction_end_e is also {
    And then something similar for the R1 subtype.
    Is there a specific reason for not collecting coverage in the same units?
    Cheers,
    Hilmar
  • Manish Verma
    Hi Hilmar ,
    Actually test_unit is transaction unit and I cannot access the monitor event(transaction_end_e) in this unit. I need to write coverage item in Monitor unit, not by extending the transaction unit.
    Thanks!
    Manish
