  2. Functional Verification
  3. SV Coverage Sequence: Bad Pointer Access Error
  • Subscribers 67
  • Views 14999
ethand
ethand over 17 years ago
This question relates to SV coverage sequences. I’m encountering a bad pointer access error when I try to compare for coverage sequences that are long and could potentially have a recursive effect. For example, the following sequence causes a bad pointer access.
       bins usb_downstream_host_sof = (
                                                      DNS_HOST_SOF => PACKET_X [*0:1] =>
The above sequence looks for SOF, followed by PACKET_X zero or one time (i.e. it’s optional), followed by SOF, etc. The entire sequence looks for 8 SOFs and 8 PACKET_Xs. The recursive aspect of this sequence is that after the first SOF, subsequent finding of another SOF will start another thread of sequence comparison while the first sequence is confirming a match for the second SOF. This process could create multiple parallel sequence comparisons for the same bin.
The simulation memory usage appears to be reaching 3.2G or higher just before the bad pointer access occurs. Is this an inherent limit of the SV coverage sequences scheme? Has anyone encountered a similar problem in the past and can suggest ways to resolve or work around this?
Thank you for your time and help!
Ethan
  • Akshayk1
    Akshayk1 over 17 years ago
    You can try repetative syntax like [*8] with just one time written pattern.
    i don't know if it wil work or not but just try and even let me know if it works.
    Akshay
