  2. Functional Verification
  3. hdl_path() for sys: error in specman v5.1
  • Subscribers 67
  • Views 15300
Sarathi
Sarathi over 17 years ago
Hi
I have a DV using specman v4.3.1 for an IP which works. I am testing it using specman v5.1 and I get the following error for the line keep soft hdl_path() == "<~/module>" which is present in the unit sys:
*** Error: Constraint for hdl_path() of unit 'sys' is not allowed.
 Suggestion: The hdl_path() of units instantiated at unit sys may
 be constrained instead.
 Is there a simpler solution to solve this issue. I do not want to append the paths to each and every event / variable that is declared in the unit sys as there are many such variables and in many files
Appreciate any help on this
Sarathi
  • StephenH
    StephenH over 17 years ago
    Hi Sarathi.
    It sounds like you've instantiated all your verification code directly in sys, is that correct?
    Cadence does not recommend this approach as it makes the code harder to re-use between projects and from block to system level.
    Instead you should encapsulate your testbench code in at least one unit that you then instantiate inside sys.
    If all your code currently is written like this:
    extend sys {
      event clk is rise('clock') @sim;
    You could fairly easily change to swap "sys" to another unit name, like this:
    unit tb like any_unit { };
    extend tb {  // instead of sys
    extend sys { // new block of code
      tb : tb is instance;
      keep tb.hdl_path() == "~/";
    This might still need some tweaking for your testbench coding style if you used any full hierarchical paths from sys, but it's definitely the right direction to be moving in.
    If you get really stuck, file a service request through SourceLink, and one of hte support team would be able to help you without you having to share any details of your code in this public forum...
    Good luck! :-)
    Steve.
