  2. Functional Verification
  3. ICCR, how to disable fullcase default branch scoring
  • Subscribers 67
  • Views 15052
RyanLV
RyanLV over 17 years ago
IES v8.2, I know "pragmas" in code to disable fullcase default branch, but code has to be updated, which is not a good way. Is there any another way, such as "set_com", to disable such scoring?
  • nlin
    nlin over 17 years ago
     Hi RyanLV,
    Your post had been posted in the wrong forum, but was put in the Functional Verification forum just today.  In the future, if you have any questions with regards to the IUS tools you can open a Service Request at http://support.cadence.com.  One of our knowledgeable AEs should be able to help you.
    With regards to your equestion on disabling the default branch.  It is possible to disable the default branch in a case by using the set_implicit_scoring -off -case command in your coverage configuration file.
    The coverage configuration file is a file given to ncelab.
    ncelab -covfile covfile.ccf
    If you want to disable both the default branch for the case statements as well as the implicit if for the if condition, you can use the same command, except take out the -case option.
     Give that a try, and if you still do have problems, please contact Cadence Support.
     Nancy
