  2. Functional Verification
  3. Transaction tracing in simvision
  • Subscribers 67
  • Views 17171
Joep Boonstra
Joep Boonstra over 17 years ago
I'm using OVM transaction level tracing in SV. I was wondering if I can have simvision render different types of transactions with different colors e.g. based on a transaction attribute. I know how to do it at signal level using mnemonics but I haven't succeeded doing this at transaction level. Anyone?
 -Joep
  • StephenH
    StephenH over 17 years ago
    Hi Joep.
    I'm not aware of any colouring options for the transactions, but I can tell you another neat facility that might do even better for you.
    If you look in the signal name area of the waveform window you should see a small plus sign just left of the transaction stream's name.
    By right clicking this plus sign, you get a pop-up menu that gives you choices about what to show when the plus sign is clicked to expand the transaction stream. For example if your transactions have an attribute "direction" which takes the value "Read" or "Write", then you can select "direction" in the pop-up menu. Next you would left-click the plus sign to expand the stream, and you would see two new transaction streams - one for "Read" and one for "Write".
    There are other more advanced things you can do such as filtering the transactions, but this subject deserves more detail than I can put in a quick forum post. Try having a look in the SimVision User Guide, in the chapter "Viewing Transactions".
  • Joep Boonstra
    Thanks Stephen. I am aware of expanding fibers/streams based on attributes and I use it a lot. It's just that colors allow a more compact (and sometimes more intuitive) representation of the different transaction types in a single fiber.
    -Joep
  • vmotel
    vmotel over 17 years ago
    Hi Joep,
    I agree that coloring transactions can also be very useful, it is complementary to the nice expanding feature explained by Stephen.
    The good news it that it is possible to color transactions in Simvision, but it is not as immediate as expanding by attribute. You need to create a TxE search for that. The transactions to be colored needs to be "accepted" by the search (use the "accept" command in the apply section), then you an use the command "set_attribute highlight color_name_or_number".
    When the result table is selected, the lines take the colors defined in the search, and the transactions in the Waveform Window are highlighted with the same colors. It can make a very nice visual effect, depending on your color choice !
    For example :
    apply {
      fiber "*::Transactions.mem_transactions"  {
        trans_type "mem_transaction" {
             if {[attribute "command"] == "READ"} {
               accept
               incr read_count
               if     {[attribute "bank"] == 0} {
                 set_attribute highlight green
               if     {[attribute "bank"] == 1} {
                 set_attribute highlight purple
               if     {[attribute "bank"] == 2} {
                 set_attribute highlight blue
               if     {[attribute "bank"] == 3} {
                 set_attribute highlight yellow
             if {[attribute "command"] == "WRITE"} {
               accept
               incr write_count
                 set_attribute highlight cyan
                 set_attribute highlight red
                 set_attribute highlight lightblue
                 set_attribute highlight pink
    exit {
    table {
      sort bank
      col fiber [fiber]
      col trans_type [trans_type]
      col command [attribute command]
      col bank [attribute bank]
      col items [items]
      row
      row total_read_count  $read_count
      row total_write_count $write_count
    Creating such a TxE search (in "text mode") should not be too long if you take benefit of the "Browse" button to interactively create it.
    Best regards,
    Vincent
