  2. Functional Verification
  3. Writing to SDRAM through Designware memory controller
  • Subscribers 67
  • Views 14421
gangireddy
gangireddy over 17 years ago
hi,
When I am writing to sdram through designware memory controller the address is being properly latched by the SDRAM. Like, if I give address as 0x0018 it will write to 0x0010(one of the address lines is not properly latched). I checked the data sheet of the SDRAM (Micron class) and the setup time is given as 2.8 ns.But, I am giving the same clock which I gave to the memory controller. Have anybody used Designware memory controller to write to SDRAM. If yes, is it the same clock the we give to both the memory controller and SDRAM or shall the clock to SDRAM to be delayed by some time from the clock given to memory controller.
gangi.
