  2. Functional Verification
  3. aspect oriented vs object oriented
  • Subscribers 67
  • Views 18187
onkarkk
onkarkk over 17 years ago
I am new to specman, i have started studying and practicing , i could not understand the precise difference between aspect oriented programming and object oriented programming , could any one explain me in this regard.
Thanks in advance,
regards,
Krishna Kishore
  • StephenH
    StephenH over 17 years ago
    The simple answer is that OOP is a way to group functionality and properties into objects. E.g. an object could be an Ethernet packet. The object's properties are "length", "payload", "address" etc. It might have methods to mapipulate the object, e.g. to print it to the screen.
    Where common functionality is needed to be shared across different objects, we use a base object to define the common properties, then we derive new object types from that base object. This is the classic OOP "inheritance" mechanism.
    Specman adds the idea of aspects ON TOP OF OOP. It does not replace OOP, and this is very important to remember, because some things are better done as pure OOP and others better with AOP.
    An aspect is simply "a view of an object" and as the name implies, we might have multiple views of an object. OK, this probably sounds a bit high-level so here's a more concrete example. Using the Ethernet packet as an example, one may have different aspects based on the address type, e.g. is it a broadcast or unicast packet. Specman allows us to define different method implementations and other properties and constraints based on the type of packet. So a broadcast packet may implement one kind of print method, and the unicast one could define a different method.
    This lets us easily change behaviour based on properties of the object, without having to use the traditional OOP patterns approach to re-use (search Google for OOP design patterns). Specman lets us control what kind of packets we generate using declarative syntax, whereas OOP would force us to be more strict about following design patterns and using procedural code to control the packet types. Thus AOP can bring big rewards when you want to randomly generate different kinds of packet.
    Having said all this, AOP does let you do really dumb things that prevent re-use or worse, lets someone break your code by adding or changing extensions to your code when you were not expecting them. But that's where good programming practices like encapsulation come into play. And of course the Specman tool has a great set of functions to review and document automatically all the code extensions, so you can quickly see what's defined where.
    Hope this helps! There are good books out there on the topic, but even working through some of the IP Verification Kit examples that ship with Incisive Enterprise Simulator (i.e. NCSim + Specman) will help you understand how it all works. A "picture" is worth a lot of words, after all ;-)
  • teamspecman
    teamspecman over 17 years ago
    Quick addition to Steven's post:
    One of the really good books on this exact subject is:
    "Aspect-Oriented Programming with the e Verification Language: A Pragmatic Guide for Testbench Developers" by David Robinson
    http://www.amazon.com/Aspect-Oriented-Programming-Verification-Language-Developers/dp/0123742102
    Team Specman
  • onkarkk
    Thank you Stephen , Now i could understand the things with confidence. Thanks for your quick reply..
    regards,
    Krishna Kishore
  • onkarkk
    thank you.
