  2. Functional Verification
  3. ncsim +gui debugging and breakpoints on system-tasks/functions...
  • Subscribers 66
  • Views 7435
ncsim +gui debugging and breakpoints on system-tasks/functions?
cubicle82
cubicle82 over 17 years ago
Is there an easy way to setup a breakpoint on a system-task, like $finish()?
I'm trying to debug some validation-code (which calls $finish on failure.) And the code is nested inside a bunch of `include files, making it difficult to directly navigate within SourceBrowser.  I thought I might take the reverse-approach, and  simply set a breakpoint on $finish itself, assuming that is even possible.
(Alternatively, I could do a text-substitution on $finish, replace it with a `define macro that calls an arbitrary unique user-task, and put the breakpoint on my task.)
  • StephenH
    StephenH over 17 years ago
    I'm not sure about doing this directly, hopefully someone else might know a proper way to do it.
    Sticking with what I do know, I'd use grep or awk to search my Verilog files for $finish, and construct a list of TCL commands to generate the line breakpoints automatically. It's a bit brutal, but should work.
    You can get the line breakpoint syntax by doing "help stop" in the ncsim prompt, or by setting a line breakpoint in SimVision and checking the ncsim console window for the TCL command it generated.
  • tpylant
    tpylant over 17 years ago
    To set a breakpoint on a line that contains a system task such as $finish, be sure to elaborate with the -linedebug switch. In SimVision, bring up the source code browser and you will see that the line numbers will not be grayed out and you can double-click on the line number that you want to break on. When the simulation reaches this line, it will stop before executing the line of code.
    Tim
