  2. Functional Verification
  3. regarding e ports
  • Replies 7
  • Subscribers 67
  • Views 17065
regarding e ports
onkarkk
onkarkk over 17 years ago
Could any one tell that  port binding ( e ports) feature is available in specman 4.3.1 or not ?? because i am getting errors when i use do bind () example ..
Thanks in advance,
regards,
Krishna Kishore
  • mstellfox
    mstellfox over 17 years ago
    Hi Krishna,
    I am pretty sure simple ports existed in Specman 4.3.1.  You might be setting the record for using the oldest version of Specman since 4.3.1 is about 6 years old.  Is there any reason why you can’t upgrade to the latest version, 8.2?
    Mike
  • onkarkk
    Thank you Mike,
    You are absolutely right regarding to record, but soon i am going to get it , but till that time i have to manage with it.. (But why i am getting errors, i have typed example as it is no mistake). it is showing at the line do bind only , when this code is executed at higher versions it is not giving any errors.
    regards,
    Krishna Kishore
  • StephenH
    StephenH over 17 years ago
    Hi Krishna.
    Can you post an example of the error message and the bind code that you're using? That will be the most efficient for us to debug.
    Steve.
  • Hilmar
    Hilmar over 17 years ago
     Hi Krishna,
    Sorry for the late response! Did you use "do bind" or the method "do_bind()".
    There are in general two ways of binding ports:
    1) Declarative using a constraint, e.g. "keep bind(my_port,my_other_port);"
    2) Procedurally, for example by extending the unit's connect_ports() method with the line "do_bind(my_port,my_other_port);".
    Best regards and I hope this was of some help,
    Hilmar
  • onkarkk
    Hi Steve,
    The error is something like this,
    *** Error :  No construct do_bind()
    Thanks in advance,
    regards,
    Krishna Kishore
  • onkarkk
    Hi Hilmar,
    Thanks for your reply,
    I have used do_bind() method , actually it was in an example.
    regards,
    Krishna Kishore
  • Avi Farjoun
    Avi Farjoun over 17 years ago
    Hi Krishna
    Port binding does exist in 4.3.1 (even though you can see it only in Museums ;-) , but procedural binding with do_bind() was not there yet (I believe it's in only from 5.0). This is why Specman tell's you :"No construct do_bind()"
    Regards
    Avi
