  2. Functional Verification
  3. code coverage
  • Subscribers 69
  • Views 15886
code coverage
liorr
liorr over 17 years ago
 I am using cadence iccr ver 6.20.
I want to watch code coverage of different tests for the same dut, but to combine the results together. (for example : i want to see if a certain fsm reached a certain state in all of the tests)
when i use the command "iccr -test 'test_*' -gui" I can see only one test at a time. Is there a way to combine the results?
 Thank You,
Lior
  • JanKindt
    JanKindt over 17 years ago
    - boot up iccr in shell mode.
    - use load_test to load all your tests
    - use union to merge the coverage data of all these tests
  • usercadence
    usercadence over 17 years ago
    Once you are in the iccr shell,
    1. Merge all the test files as follows;
    merge -code <path>/test_name* -output <test_grp_name>
    2.Then load this test merged test as follows:
    load_test <path>/test_grp_name
    3. Then view the output results of the merged test by typing "view"
  • usercadence
    I am testing a block written in VHDL and I have two behavioural models and I have tests for both these models. I notice that when i try to merge the tests from both the BHVs, some conditions are not hit but individual tests hit those conditions. I was wondering there is any way to merge the test files correctly or in any particular order. I do not get any error while I try to merge, except that the DUT is not specified. I use the following steps to merge and view the code coverage:
    Any suggestions/solutions would be very helpful.
